Superficial rust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, Jul 21, 2019.
  1. Jul 21, 2019 at 12:13 PM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    So, I am getting some little spots of superficial rust here and there on my Taco frame. When you consider the fact that it basically never stopped raining here 2016-2018 I consider that a win for Toyota.
    I am thinking about addressing it, given the rust history of Taco frames. My question is, how? Never done this before. I assume that I should just use some steel wool or something to remove the rust and then hit it with some protective paint? If not, what all do you folks do? If so, any recommendations on a protective paint for this application?
    Thanks in advance.
    Dryfly24 and Hobbs like this.
  2. Jul 21, 2019 at 12:14 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    It rained for three years straight?? If I were you, I would relocate. That truck is gonna rust.
  3. Jul 21, 2019 at 12:15 PM
    AgingDisgracefully
    Peter
    Well, the Dude is exaggerating, but they were three of the wettest years I think I've ever seen here in Tar Heel land, and for long stretches of 2018 yes, it rained pretty much all the time.
    turbosnail and Hobbs[QUOTED] like this.
  4. Jul 21, 2019 at 12:17 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Jeebus man, where do you live? On Noah’s Ark?
  5. Jul 21, 2019 at 12:18 PM
    AgingDisgracefully
    Peter
    I can tell you, by day 4 or so of Hurricane Florence last fall I was wondering if I should have bought an ark instead of a Taco :rofl:
    Dryfly24[QUOTED] and Hobbs like this.
  6. Jul 21, 2019 at 12:20 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Stay dry fellow dude
  7. Jul 21, 2019 at 12:36 PM
    ICU1
    ICU1 Well-Known Member
    Need to post photos. Have you done the A/C drain fix?
  8. Jul 21, 2019 at 12:38 PM
    AgingDisgracefully
    Peter
    That's (the A/C fix) coming. I'll go take some pics now.
  9. Jul 21, 2019 at 12:40 PM
    ICU1
    Use some dish soap when you do the A/C drain fix, makes life easier
  10. Jul 21, 2019 at 12:47 PM
    AgingDisgracefully
    Peter
    This is by far the worst spot. It is just behind the passenger side cab mount. Its looks pretty superficial. Is this bad for a 2016 Taco?
  11. Jul 21, 2019 at 12:48 PM
    AgingDisgracefully
    Peter
    I should add that the greasiness around the one rust spot is just bc I had CLP on my finger when I rubbed it.
  12. Jul 21, 2019 at 12:49 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    no
  13. Jul 21, 2019 at 12:50 PM
    AgingDisgracefully
    Peter
    Well, that makes me feel better.
  14. Jul 21, 2019 at 12:53 PM
    AgingDisgracefully
    Peter
    So, I was thinking about the following:
    1. Steel wool the rust out and hit it with protective paint
    2. Hit it with Fluid Film or something like that every fall.
    3. Repeat 1 as necessary elsewhere.
    Sound like a plan? (I.e. any flaw in this plan?)
    Stocklocker and ICU1 like this.
  15. Jul 21, 2019 at 12:57 PM
    jmneill
    SE
    FF is good stuff, I've used it on Jet Skis for years. If you go the paint route, a lot of people really like POR15 in the can. (non aerosol)
  16. Jul 21, 2019 at 12:59 PM
    AgingDisgracefully
    Peter
    So they just paint it on with a brush? Thanks.
  17. Jul 21, 2019 at 1:04 PM
    jmneill
    SE
  18. Jul 21, 2019 at 1:07 PM
    AgingDisgracefully
    Peter
    Thanks man! Did you bother with a respirator when you put this on? In the discussion of the semi-gloss version of this product someone seemed very concerned about that.
  19. Jul 21, 2019 at 1:10 PM
    eon_blue
    Azusa, CA
    I would at least wear some kind of mask when you're scuffing the rust spots off the frame...I did that after a few beach trips left some surface rust on my frame and let me tell you, you don't wanna breathe that crap in.
  20. Jul 21, 2019 at 1:11 PM
    jmneill
    SE
    I have both on hand, but have yet to spray the POR15.
    I've used the Preval on two occasions. Once with Norrell's Moly Resin, and once with Cerakote. Worked fine both times.
    The Preval is exactly what it looks like, a crude way to semi successfully spray paint. (perfect in my opinion, for a pickup frame)
