Supertech gear oil ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Feb 23, 2018.
  1. Feb 23, 2018 at 5:50 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Just changed the gear oil in my new to me truck, the front diff was blacker than black. Rear and t case looked like new amber fluid. Im on a “fluid” budget rn for new gear oil since some other truck parts got the best of the wallet lol. How does the supertech gear oil do? I am usually a Valvoline guy and this is the 1st time i went with something other than Valvoline or mobil 1. Thoughts or reviews on supertech gear oils?
  2. Feb 23, 2018 at 6:17 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    On BIOG forum they claim iy's no worse than any other dino oil/gear oil.
  3. Feb 23, 2018 at 7:00 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I’m running the “synthetic blend” in my diffs and transfer case. I noticed no difference from the original factory fluid.
    757yotas[OP] likes this.
  4. Feb 24, 2018 at 8:30 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've been using Super Tech gear oil since it was introduced. Lots of miles - no issues. You do not need to spend $$$ on boutique lubricants.
  5. Feb 24, 2018 at 8:43 AM
    757yotas
    Virginia
    2007 TRD Sport
    I have heard it is actually alot better than people give it credit. I plan on doing a drain and fill after 15k to see how it does then after if all is well stick it to the 30k recommended mark.
  6. Feb 24, 2018 at 8:46 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    SuperTech IS Valvoline. You win!
    Edit: I'm not a advocate of Valvoline myself but do realize it's as good as anything else out there in it's class. Since I do the 3K mile oil changes of dino oil, I do use it in my crankcase. With fresh synthetics in the diff's, I doubt they really ever need changing again unless I cross high water.
    edit: I recant statement about it being Valvoline as that was a at least a 20 yr. old rumor I go off of and it seems to be impossible to prove. Still think it's a good oil at a good price if changed at rec'd intervals.
  7. Feb 24, 2018 at 10:16 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    OP, do you have a limited slip rear diff? My 2007 does. If so you need to add friction modifier.
  8. Feb 24, 2018 at 12:28 PM
    757yotas
    Virginia
    2007 TRD Sport
    Yes i do and i added 4oz of it when i changed it
