Superwhite Monster
Discussion in '2nd Gen. Builds (2005-2015)' started by Spoonman, Dec 17, 2011.
  1. Nov 9, 2014 at 7:29 PM
    #2641
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Alberta
    Seemed like the rear of the diff is flopping. And there's some leakage. Looks to be some leakage too. Kinda excited to go see what's up.
  2. Nov 9, 2014 at 7:32 PM
    #2642
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Wonder if you ripped the ear off of the diff for the rear mount.
  3. Nov 9, 2014 at 7:45 PM
    #2643
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    somebody just needs a solid axle....
  4. Nov 9, 2014 at 8:12 PM
    #2644
    Spoonman
    Jamie
    Alberta
    Could be.
    Fuck I REALLY need to sas this
  5. Nov 11, 2014 at 10:19 AM
    #2645
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Hey I was wondering just how much modding you had to do for your Marlin Crawlbox? Im thinking of pulling the trigger on one, but want to try to have everything lined up. Did you order new drivelines or have yours extended? Do you remember the lengths? Also they mention the crossmember may need modified too???
    Any help or links would be awesome
  6. Nov 11, 2014 at 10:38 AM
    #2646
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I did. Snapped the front diff mount on the collar.
    Pics in my build thread.
  7. Nov 11, 2014 at 10:58 AM
    #2647
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Ohhh.... Good catch, thanks
  8. Nov 11, 2014 at 11:17 AM
    #2648
    Spoonman
    Jamie
    Alberta
    Pretty much. That's it for driveline. Other than that it's fairly straight forward. Just bring a big hammer to beat the living hell out of your transmission tunnel.
    It's a pretty sensetive job. I had it all together, then had a little leak and had to pull it all apart again and turn a set screw in about half a turn.
  9. Nov 11, 2014 at 12:21 PM
    #2649
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Ok good to know. Im kinda torn now between going with Inchworm now or not:confused:
    Did you go with the lower gears? Im already running 4:88's so I'm tempted to save a few hundred bucks and stick with the normal setup.
  10. Nov 11, 2014 at 12:37 PM
    #2650
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Go with 4.7 gears. will give you a third range to drop into. Well worth the money.
  11. Nov 11, 2014 at 12:38 PM
    #2651
    Spoonman
    Jamie
    Alberta
    I have auto tranny, factory tcase, and 4.7 crawlbox. Then 4:88. Crawl Ratio is 207:1 it's great.
    Oh and all the crawl boxes are the same...the only difference between inchworm and marlin are he bearings. Same case I heard.
  12. Nov 11, 2014 at 1:57 PM
    #2652
    Spoonman
    Jamie
    Alberta
  13. Nov 11, 2014 at 2:01 PM
    #2653
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Pics?
  14. Nov 11, 2014 at 2:09 PM
    #2654
    Spoonman
    Jamie
    Alberta
    Wow I went full retard. I forgot to post the video. Fixed it
  15. Nov 11, 2014 at 2:12 PM
    #2655
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    actually tore some metal out wow. Thats going to be a fun fix.
  16. Nov 11, 2014 at 2:32 PM
    #2656
    Spoonman
    Jamie
    Alberta
    I'll have to figure something out..maybe have my fabricator make a whole new mount.
  17. Nov 11, 2014 at 3:42 PM
    #2657
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    A bit different than what happened to mine but same end result.
    Looks like your oil pan is intact and it's the diff seal that is leaking?
  18. Nov 11, 2014 at 4:22 PM
    #2658
    Spoonman
    Jamie
    Alberta
    Not sure what's leaking yet, almost looks to be the crack between the two halves of the clamshell.
  19. Nov 11, 2014 at 4:26 PM
    #2659
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Any idea of the cause?? Two much torque?
  20. Dec 9, 2014 at 10:13 PM
    #2660
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    You still kicking?
