Superwhite Monster
Discussion in '2nd Gen. Builds (2005-2015)' started by Spoonman, Dec 17, 2011.
  1. Aug 9, 2012 at 7:38 PM
    #281
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Got some floor mats dirt cheap. Really needed.
  2. Aug 10, 2012 at 8:58 PM
    #282
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    I need reliable wheelin buddies. I want to go for a night run right now!!
  3. Aug 10, 2012 at 9:21 PM
    #283
    Sproulesxrunner
    Sproulesxrunner Well-Known Member
    Canada
    08 Xrunner
    Too much for TW to know
    Calgary boy eh? I have definitely seen your truck before. Your truck definitely makes me question myself sometimes why I bought a xrunner instead of a 4X4.
    P.S. I like your dog too haha.
  4. Aug 10, 2012 at 11:57 PM
    #284
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Thanks a lot! I couldn't live without 4x4...
    Spent some quality time adjusting my PITA rear brakes tonight..
  5. Aug 11, 2012 at 4:41 PM
    #285
    Sproulesxrunner
    Canada
    08 Xrunner
    Do you own a shop? Why does your truck need aligned so much?
  6. Aug 11, 2012 at 4:48 PM
    #286
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    No alignment there!
  7. Aug 11, 2012 at 4:56 PM
    #287
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    I work at a shop is all. Max is correct I am not doing an alignment there.
    However I do perform alignments fairly often... My steering wheel is off center again. So I will require another alignment soon(once I get the motivation). Not sure why things keep moving around on me. I checked my frot end last night and discovered my left from outer tie rod heim has developed play!! After only 6000km! This All-Pro LT is not worth the hassle! The front control arm bushings are squeeking like CRAZY as well.
    But the top things on my list are:
    -Both front wheel bearings
    -A few idler pulleys
    -Starter
    -Align again
    Ugh.
  8. Aug 11, 2012 at 4:57 PM
    #288
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    pay to play and all that, sure sucks huh haha :(
  9. Aug 11, 2012 at 5:00 PM
    #289
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    My cam tabs seem be pretty solid at this time, I welded behind the tabs best I could.
    Max: Yep.. I would expect good quality stuff for the price I paid though. Especially from a reputable company such as AP. I really am not impressed with it so far. Walke Evans shocks has already gotten really soft & weak as well.
    Oh yeah...going to need a steering rack soon too. My p/s is giving up.
  10. Aug 11, 2012 at 5:11 PM
    #290
    Sproulesxrunner
    Canada
    08 Xrunner
    I wasn't meaning your last post haha. I knew you were doing the rear brakes there. It was just when I went though your whole build thread and it seemed like ever second post you were getting an alignment haha. Do you do alignments at your shop? what is the price? I have 51K kms on my X and I should get an alignment after I installed the drop kit.
    Are your idler bearings squealing? I have one bearing squealing and it is driving me crazy.... however it isn't an OEM one and I still need to find out the specifications on it. It is a bearing on my NST overdrive kit for my supercharger.
    Here is my build thread if your interested ->http://www.xr-underground.com/forum/showthread.php?t=47848
  11. Aug 11, 2012 at 6:41 PM
    #291
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Spoon, is your uptravel limited right now from the fenders?
  12. Aug 11, 2012 at 8:20 PM
    #292
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    My tire smashes into the front fender with the fury of 1000 jesus's.
  13. Aug 11, 2012 at 9:03 PM
    #293
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Why don't you clearance? Whats the point of running a LT if you can't even utilize it?
  14. Aug 11, 2012 at 9:09 PM
    #294
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    I haven't really check out much up travel I'm missing out on. I feel like I'm
    Not missing much simply because the weight of the truck will push the fender up, and let me use the up travel. I regret not doing SAS.
  15. Aug 11, 2012 at 9:18 PM
    #295
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
  16. Aug 12, 2012 at 10:12 AM
    #296
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS is an even bigger endeavor. Why would you need a SA? Looks like you are doing fine with the AP LT kit. (Besides clearance for tires) I advise you to look at my friends build. NwiTACO. (Who I am sure you know of) Guaranteed the hardest wheeler with a AP LT kit.
    He does everything I can do (mostly) on the trail. The only thing he does better is he can drive faster (if I had probably suspension geometry and shocks that aren't blown/leaf springs that are destroyed) I would be fine. His biggest defeat over me is that he can DD his truck, he drives round trip over 1000 miles to go wheeling for days. I cannot do that... Though in my mind, if a truck is built RIGHT, it should NEVER be able to drive on the road.
    http://www.pirate4x4.com/forum/showpost.php?p=14513759&postcount=16
  17. Aug 12, 2012 at 8:58 PM
    #297
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Quite the shit day I had. Went wheeling, it was great. A few of my idlers let go on the way home...had to get towed. *Took out a small coolant line as well. *Turns out my tensioner pulley was messed up at the same time, a bunch of the belt got jammed behind it. *Then the bolt for the tensioner pulley broke. *So I need a new tensioner too...looks like a pain..
    I now need
    Tensioner
    2 idler pulleys
    Belt
    Coolant line
  18. Aug 12, 2012 at 9:08 PM
    #298
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Good thing you have a lift :)
  19. Aug 12, 2012 at 10:03 PM
    #299
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Why max?
    anyone ever replaced a tensioner?
  20. Aug 12, 2012 at 10:11 PM
    #300
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    I haven't but you have to pull the alt and a/c compressor. Just nicer to work with a lift that's all, especially when you have all that shit to replace. Should be pretty straight forward though. The idlers are easy.
    http://www.fjcruiserforums.com/foru...154-idler-pulley-bearing-failure-what-do.html
    I can't imagine why you can't replace just the bearing/idler.
    However...
    Tensioner Pulley Warning!
    Apparently the upper pulley part number cross references as the pulley on the tensioner and some have ordered just the pulley instead of the entire assembly. After further research (not by me) it turned out that this was not the case and that the pulley did not work. Apparently the spacing and dimensions are incorrect. My suggestion is just to replace the entire tensioner assembly and avoid any potential damage that could occur by installing the wrong pulley.
    Suppose you could pull the idler off, press out the bearing, source a new bearing and have a machine shop machine you a bushing.
    or even in the interim you could pull of an idler and pull of the tensioner idler and compare, then you could come up with a solution from there.
