Superwhite Monster
Discussion in '2nd Gen. Builds (2005-2015)' started by Spoonman, Dec 17, 2011.
  1. Sep 7, 2013 at 11:50 PM
    #1641
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    yeah saving for a couple years, now its time to do one major build and hopefully not have to redo anything afterwards, will only have to get it caged but that will probably happen either next fall or winter if i decide to do it.
  2. Sep 8, 2013 at 12:00 AM
    #1642
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Alberta
    That's madness. Cage would be nice to have. What kind of LT in front are you going to use?
  3. Sep 8, 2013 at 12:08 AM
    #1643
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    still undecided on how wide i want to go, if 3.5 over per side it will be the dirt designs kit, if 2 over per side im leaning towards total chaos cause of the stainless 1 inch uniballs, since nobody makes 1.25 uniballs in stainless for the allpro kit.
  4. Sep 8, 2013 at 6:16 AM
    #1644
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
  5. Sep 8, 2013 at 10:43 AM
    #1645
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
    Was wondering what steered you away from getting a rear axle from a TRD-OR, ive been looking into this option as a cheaper way to lock my rear TRD sport. I havnt had much luck in finding ANYONE that has done this.
  6. Sep 8, 2013 at 10:54 AM
    #1646
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    That's because an arb in the non elocker housing is way stronger, and you don't have to worry about spinning bearings.
  7. Sep 8, 2013 at 11:13 AM
    #1647
    Geem750
    Brandon
    Okanagan, BC
    07 DCLB
    For someone that will only need the locker for 5% of the wheeling i do.. i dont think the price of an ARB is entirely worth it. But i want a locker for that 5% cuz it might save my ass a winching from my brothers jeep :p
  8. Sep 8, 2013 at 5:16 PM
    #1648
    Spoonman
    Jamie
    Alberta
    Way more simple to go with arb. Glad I didn't use a trd rear end. Whole rear axle must be replaced, then the wiring, switches, harnesses, blah blah blah. Arb is really simple!
  9. Sep 8, 2013 at 6:48 PM
    #1649
    Geem750
    Brandon
    Okanagan, BC
    07 DCLB
    yeah but for the mild wheeler, whats the cost comparison? maybe its not worth it to swap at all but there's a wrecker near by that has these axles as far as i know
  10. Sep 8, 2013 at 7:07 PM
    #1650
    Spoonman
    Jamie
    Alberta
    Well if you can do it cheaper, by all means do that.
    However, from mild to wild, ARB will get the job done. And you'll have on board air, which you'll need for wheeling.
  11. Sep 8, 2013 at 7:18 PM
    #1651
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    To add to this arb vs e-locker discussion... I've been less than impressed with the e-locker. It works but not exactly when you want it to. It takes some coaxing to get it to engage.
  12. Sep 8, 2013 at 7:20 PM
    #1652
    Spoonman
    Jamie
    Alberta
  13. Sep 8, 2013 at 7:32 PM
    #1653
    SconnieHailer
    Marc
    ooo, no fun there... Could you use a back up CO2 tank?
  14. Sep 8, 2013 at 7:37 PM
    #1654
    Spoonman
    Jamie
    Alberta
    It's possible I suppose. I'd need a regulator to keep the lressure below 100 psi. But it would work. However, I just carry an extra compressor.
  15. Sep 8, 2013 at 7:45 PM
    #1655
    SconnieHailer
    Marc
    pick your poison I guess.
  16. Sep 8, 2013 at 7:48 PM
    #1656
    Geem750
    Brandon
    Okanagan, BC
    07 DCLB
    is that your only complaint? because it sounds about the same as trying to get into 4Hi. i have to roll the truck a bit to get it to engage.
    the way i see it, locker and compressor purchase and install is what, 3k? if i could get the offroad axle and install for less than a grand id be thrilled.
  17. Sep 8, 2013 at 7:53 PM
    #1657
    SconnieHailer
    Marc
    It takes a bit longer than 4wd to engage sometimes... but yea, when it engages it works fine. Used it for 3 miles of trail coming out of shoshone lake which was all rock obstacles up-hill this summer. Definitely helped push me over some stuff I may have had to hit a second time if I was open diffd.
  18. Sep 8, 2013 at 8:07 PM
    #1658
    Spoonman
    Jamie
    Alberta
    3000 for a rear arb is excessive. I paid a little over that for f&r arb and new gears, installed in new housings.
    Probably 1500. Depends on if you want a complete differential, or you want to install the locker yourself.
    I would be surprised if you could find a complete e-locker rear axle with the correct gear ratio for less then $1000.
  19. Sep 8, 2013 at 8:18 PM
    #1659
    Geem750
    Brandon
    Okanagan, BC
    07 DCLB
    Challenge accepted :p ill be looking into it. im not interested in busting knuckles trying to do installs. did you install your front/rear arb yourself?
  20. Sep 8, 2013 at 8:39 PM
    #1660
    Spoonman
    Jamie
    Alberta
    I got complete diffs from ECGS. I don't have the right tools to install them myself.
