Support carrier bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zac, Oct 1, 2009.
  1. Oct 1, 2009 at 7:25 PM
    Zac
    Zac [OP] Member
    Zac
    tucson
    00 Tacoma SR5 4X4
    3-4 inch lift
    I am wondering what degree of difficulty it is to install my Driveshaft support carrier bearing?
  2. Oct 1, 2009 at 7:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    are you talking about removing and replacing the carrier bearing entirely from the drive shaft?
  3. Oct 1, 2009 at 8:21 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Are you having carrier bearing vibes? Is this why you want to change out your Carrier?
  4. Oct 1, 2009 at 8:29 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
  5. Oct 2, 2009 at 12:39 AM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    Not hard 1-10 id say a 5 if you know how to torque a wrench
  6. Oct 5, 2009 at 1:50 PM
    Zac
    Zac [OP] Member
    Zac
    tucson
    00 Tacoma SR5 4X4
    3-4 inch lift
    not only am i having vibrations, but when i grab my drive shaft i can literally lift it up and down in the mount i think the entire rubber part of the bearing is gone.
    and i am trying to find a respectable website to order it from since they seem less expensive any suggestions.
  7. Oct 5, 2009 at 3:41 PM
    j_cyrus
    j_cyrus Well-Known Member
    Rickman TN
  8. Oct 5, 2009 at 7:40 PM
    ETaco23
    Evan
    PNW
    I tryed lowering mine to get rid of the vibes, but no luck, and I didnt want to mess with it anymore. I didnt want to spend anymore trying to fix the vibe so I did a forsure fix, and got a Tom Woods one piece shaft. :) Best thing ive done for my truck...
  9. Oct 5, 2009 at 7:51 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Use the stock jack and some 2x4's or 2x6's. I just dropped and installed a spacer this last weekend.
  10. Oct 6, 2009 at 6:42 PM
    Zac
    Zac [OP] Member
    Zac
    tucson
    00 Tacoma SR5 4X4
    3-4 inch lift
    j_cyrus thanks for the site just ordered it. I have ordered it from two other sites and they just take my money then send it back and tell me it was out of stock hope this site works better.
    Kilted Chiken is it basically self explaintory or did you have a manule or something?
  11. Oct 6, 2009 at 6:48 PM
    4x4Runner
    Drunken Sailor
    KDSS
    In your case I would replace it and torque everything to spec. Lift it up and slide the jack under to support while you but the bolts back in. Pretty self explanatory.
  12. Nov 5, 2009 at 7:37 AM
    rustyshakelford
    rustyshakelford Well-Known Member
    Brett
    Magnolia, TX
    i need to do this also. does anyone have the part number for the u-joints?
    brett
