Support for topper (for RTT)
Discussion in 'Tonneau Covers, Caps and Shells' started by GrizzlyGus, Apr 17, 2018.
  1. Apr 17, 2018 at 9:43 AM
    GrizzlyGus
    GrizzlyGus [OP] Member
    3rd gen double mgray
    Anyone ever had a support (rollbar type) made to rest against the top of the cap(front and back) and be bolted in the bed floor itself to keep the bedsides and the cap from carrying all the weight? I would like to build one but can't find anything.
  2. Apr 24, 2018 at 9:49 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
  3. Feb 8, 2021 at 9:42 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Catfish21 and stickyTaco like this.
  4. Feb 9, 2021 at 5:31 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  5. Feb 9, 2021 at 6:18 AM
    Overland&UpMoutains
    Parker
    Deleware
    Why the spacers? Why not the frame on directly on bottom of the roof, drill through and attach the rack directly to the frame.
    also your frame isn’t attached to the bed? The whole point is to transfer the weight to the bedroom
    unless that’s the plan and your just getting there and I’m a dick lol
  6. Feb 9, 2021 at 1:46 PM
    nzbrock
    Noah
    San Marcos, TX
    Spacers because the roof is not flat. The ARE MX is a compound curved surface. I also wanted to get the frame level with the bed, and the topper roof tapers down towards the back.
    Attaching directly to the aluminum extrusion using tnuts is extremely difficult to line up. This is why I ended up using L brackets off the side.
    Yes the whole point is to tie it down to the bed rails. Since I am trying to get these vertical supports to be as close to the topper as possible, it takes some precise measuring. Mine will not just be inline with the roof frame, it will be angled outward to match the topper walls, but always towards the back (or front). So essentially angling in 2 directions. This is much more complex then the ARE CX reinforcements.
    I will probably add some 1010 bars across the top at some point, but my goal was to get the frame in first so I could get my measurements right.
    Here's a picture, hopefully that helps explain it.
    Steves104x4 likes this.
  7. Feb 10, 2021 at 9:47 PM
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    I bought my camper with rack rails so I could do just this. I’m going to make a frame go to them in the inside.
  8. Feb 11, 2021 at 2:19 AM
    Overland&UpMoutains
    Parker
    Deleware
    Yea I see now. And makes sense re the space! Thanks for explaining.
    what are the spacers made of?
  9. Feb 11, 2021 at 4:59 AM
    nzbrock
    Noah
    San Marcos, TX
    Printed in PETG (polyethylene)
    They bolt into the top of the 1020 rail with a 1/4-20 bolt and tnut. That's just to hold it in place for aligning the whole thing.
    There are long stainless bolts that go through the roof with a 2" fender washer and nut up against the fiberglass on the inside to make them act like studs. Then the whole frame assembly gets lifted into place and those other holes on the spacers (as well as the L-brackets) line up with these studs. They then get bolted onto the studs with another nut and washer. This was really the easiest way for me to get it all aligned and mounted. I left extra space on the spacer to accommodate the nut that is up against the fender washer. Even if it becomes loose, the bottom nut will take over with the tension once everything is tightened down.
