Supra Maf? Anyone done this on here?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sportsterchop200, May 3, 2013.
  1. May 3, 2013 at 9:30 AM
    sportsterchop200
    sportsterchop200 [OP] Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Just reading on some other forums about swaping out the stock MAF with a Supra one for the larger diameter? It seems to mostly be people with a S/C. Just curious if anyone on here has done this or has any information for it.
  2. May 3, 2013 at 5:31 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    I would like to know this as well. Also want to know if the supra TB works.
  3. May 3, 2013 at 5:37 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  4. May 3, 2013 at 8:43 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Umm...well...
    When i was into supras..we used to swap the MAF housing for a lexus V8 one. What that did was let in about 25% more air..BUT your ECU doesn't know it. So you had to get an AFPR and a Piggy back plus 550cc injectors(about 25% bigger over stock 440cc) and then tune it.
    Unless you have a good fuel system and good way to actually control it..i would NOT do it.
    also pointless on a non FAI truck.
