SupraYota
Discussion in '2nd Gen. Builds (2005-2015)' started by LsuMeDesigner, Jan 23, 2013.
  1. Feb 5, 2013 at 9:27 AM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Are you assembling the lower end, or having a shop do it?
  2. Feb 5, 2013 at 9:51 AM
    #62
    LsuMeDesigner
    LsuMeDesigner [OP] Well-Known Member
    I'm just gonna have a shop do it. I got my pistons .5 over so they are going to need to bore it over, hot tank it, and rebalance the crank.
  3. Feb 5, 2013 at 9:56 AM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That will be a nice bump up in litre size. ^_^
  4. Feb 5, 2013 at 11:04 AM
    #64
    LsuMeDesigner
    Ha not soo much my friend. It's .5mm oversize.
    Stock: 86mm bore and 86mm stroke- 86^2*pi/4=area of piston. Area*stroke* number of cylinders/1000000=2.997 liters
    New pistons are only 86.5mm bore which comes out to 3.0323 liters. :(
  5. Feb 5, 2013 at 11:06 AM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Massive! ;)
    Oh yeah. Make sure to ask them that they are boring the cylinders to .004" over that of the pistons. Give you proper room for expansion of those forged pistons.
  6. Feb 5, 2013 at 12:07 PM
    #66
    LsuMeDesigner
    Is that serious?? I am no engine builder....I can work on them but when I comes to those kind of tolerances I am not the professional.
    Should I tell this guy that?? I mean he knows what he's doing and built the LS in my buddy's truck that laid down 750hp.
  7. Feb 5, 2013 at 12:16 PM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For forged pistons, that is the industry standard clearance, with boost. Otherwise if it is any tighter, you run the high probability of piston slap, once they heat up. Especially with boost.
    I am sure that he knows what he is doing though, if he has been building performance engines for a while. More for you to know, if you really wanted to.
  8. Feb 5, 2013 at 12:59 PM
    #68
    LsuMeDesigner
    Yeah thanks for that knowledge!
  9. Feb 5, 2013 at 3:21 PM
    #69
    BradyT88
    BradyT88 Well-Known Member
    So what exactly is the point of boring? I understand that is is to increase your engine's displacement, but I just looked into it some and it looks like .060" over bore is about as big as bores get and even on a v8 that hardly nets much of an increase. On the 1GR-FE that would only net us a 0.13L increase. Looks like the stroker kit like Torspd has is the best way to increase displacement.
  10. Feb 5, 2013 at 3:24 PM
    #70
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
  11. Feb 5, 2013 at 4:32 PM
    #71
    LsuMeDesigner
    I'm doing it just to have fresh cylinder walls. I would rather bore out a little then buy stock bore pistons an find out there is scarring.
  12. Feb 5, 2013 at 7:26 PM
    #72
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    What are you going to do with the rear weight wise to ensure the truck actually hooks up?
  13. Feb 7, 2013 at 5:27 AM
    #73
    LsuMeDesigner
    Ummm hope and pray doesn't work?????
    Idk man....I'm gonna make the power I want and then do what I can to hook.
  14. Feb 7, 2013 at 5:31 AM
    #74
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Build then refine.
  15. Feb 7, 2013 at 7:43 AM
    #75
    LsuMeDesigner
    Alright one of the reasons Im making this thread is to tell people the pros and cons of the build, as well as say what parts work best and what parts are flukes.
    The stubby antenna from Craver Speed is a great looking antenna, but where I live (Baton Rouge LA), I had 6 channels programmed on my factory radio and now only 1 of those comes in clear and another comes in but very patchy.
    Also picked up my drop kit that I ordered from XII Performance, parts look like they are in great shape and quality stuff.
    This is not a big deal, but when you are a company that 99% of your business is targeted to a narrow group of truck owners, then you would think that you would want to advertise as much as possible to capture that small market that you appeal to.
    In the drop kit I ordered XII did not include any stickers or advertising products. :(
    Not really a big deal, but just not good business on their part.
  16. Feb 7, 2013 at 7:48 AM
    #76
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I must have gotten your stickers. Lol.
    Those craven speed antennas are known for terrible reception. I thought you already knew, or I would have said something.
    Scion tC, 350Z, or S2K antennas. Mine is an modified S2K.
  17. Feb 7, 2013 at 8:05 AM
    #77
    LsuMeDesigner
    Nahh...had no clue.
    I saw that a couple people used them on their builds and didnt see any complaints.
    Ohhh well..guess I need to get an Ipod adapter.
    **Also I held off on ordering the engine internals, after talking to the supra guys, they think Supra Turbo internals should be plenty enough and about 1/5th of the price. Soo im bidding on a couple now, if I dont score any by end of the week ill pull trigger on new stuff.
  18. Feb 7, 2013 at 4:14 PM
    #78
    RMerritts
    RMerritts Member
    cant wait to see the progress, im starting my turbo lsx swap when mine gets back from the body shop..
  19. Feb 7, 2013 at 5:14 PM
    #79
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I think you have your goals backwards. Making that power on a 2JZ is cake, you might want to consider focusing your attention to the little things like tire compound, traction, cage, rear end weight, etc. etc. if you want to commit this build to the strip IMO.
    Lol, come on Tor you konw better then that. Think the whole project through, then build. Otherwise you end up not using and cutting shit back that doesn work, I.E. wasting money.
  20. Feb 7, 2013 at 5:24 PM
    #80
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
