Supreme Supension Shackle Mounts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bradne1, Nov 14, 2023.
  1. Nov 14, 2023 at 4:55 PM
    bradne1
    bradne1 [OP] New Member
    The search function failed me, but has anyone used the Supreme Suspension Shackle Mounts for ACTUAL recovery? They look better than the "Demon" mounts, however the weak point is likely the crossmember that they mount to (with one bolt). I was thinking of welding a plate to the mount and adding a second bolt to the innerside of the cross member.
    https://www.supremesuspensions.com/...and-2x-d-ring-shackles?variant=42447841689851
    Maybe I am overthinking this but I like having a couple of good closed shackles on the front instead of the single open hook on the passenger side.
  2. Nov 14, 2023 at 8:09 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    welcome.....they are not for recovery - just for show.....the problem is what they bolt to is not strong enough and only one bolt to attach it? really?
    LOLLY likes this.
  3. Nov 14, 2023 at 8:23 PM
    bradne1
    That is my thought too, however since the factory tow hook on the passenger side is bolted on the same cross member (with two bolts) I am thinking the engineers must consider it somewhat strong enough as a connection point.
    It just boggles my mind that Toyota did not put decent connection points on the front of this truck.
