Sure its a long shot but......
Discussion in 'Arizona' started by Smokey11, Mar 5, 2012.
  1. Mar 5, 2012 at 4:29 PM
    Smokey11
    Smokey11 [OP] You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    Anyone want to trade my chrome rear bumper for thier black one ? Great shape only 4K miles on it, last chrome part on the pickup and I hate it !
  2. Mar 5, 2012 at 8:57 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    You could always Plastidip it, ColtsTRD on here did and it looks great!
  3. Mar 5, 2012 at 10:02 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Cortland, I was just thinking about doing that to mine. Or using some of this extra Rustoleum bedliner I have......
  4. Mar 6, 2012 at 5:48 AM
    Smokey11
    Jeremy
    Anchorage, Ak
    Yeah I might go that route or might just powder coat it idk, moving to Alaska so not sure how the Plastidip would hold up in the weather.
  5. Mar 6, 2012 at 9:51 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Like Cortland said, I plasti-dipped mine and its held up with no issues. No chips, cracks or anything and it cleans up really well. Just throw some armor on it.
  6. Mar 6, 2012 at 10:03 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    It says Plasti has a tolerance of -30 F. I'm not sure where you're headed in AK? Elmendorf/Richardson... but I've been up there 12 times and it's a brutal climate like AZ, but just on the other extreme. Hate to see your bumper peel away in the winter...
    http://www.plastidip.com/docs/plastidip_uv.pdf
    Az
  7. Mar 6, 2012 at 10:24 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    dude, find yourself a good Powder coating guy. Mine charged me 150$ to powder my bumper and all 4 rings off the TRD beadlock rims. I had to remove everything and drop off...but thats pretty good i think
  8. Mar 6, 2012 at 11:46 AM
    Cortland
    Cortland
    California
    1 or 2 cans of Plastidip is super cheap and if you don't like it then peel it off.
  9. Mar 6, 2012 at 11:50 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Agree with powdercoat. That will never come off
  10. Mar 6, 2012 at 11:50 AM
    Smokey11
    Jeremy
    Anchorage, Ak
    Yeah headed up to ELMO for 4 years so I want it to last, might just do what VolcomTacoma2011 said and just coat it. I was just seeing if anyone had one laying around was all.
  11. Mar 6, 2012 at 11:54 AM
    VolcomTacoma
    Jeff
    NorCal
    That's what I did with mine, I'm sure you could get just the bumper done for probably around 100$ tops.
    Be careful when taking off the plastic pieces on the bumper, I broke the 2 side ones on accident, 60$ each for them. You have to slide them off, I forget which way, since you can't access the nuts on them, might be able to once the bumper is off, I was stupid and tried to take it all off BEFORE i got the bumper off. just go on a toyota parts place and look up the bumper, You'll see the 2 end plastic piece are attached with 2 bolts that slide on or something like that, and they come with some sort of thread tight stuff already.
    Also, had to use a breaker bar to get the bumper off the frames. and had to take a hammer to it to get it back on. the bumper frames are almost under tension when its on, so when you go to get the bumper back on, you'll see that it wont fit by like 1/4 inch. It sucks when you're trying to do it by yourself and you realize you can't do it lol!
  12. Mar 6, 2012 at 12:02 PM
    Smokey11
    Jeremy
    Anchorage, Ak
    OK good deal thanks for the info !!!!
  13. Mar 6, 2012 at 12:13 PM
    VolcomTacoma
    Jeff
    NorCal
    NO prob! As long as someone learns from our mistakes, its worth it! :D
  14. Mar 6, 2012 at 2:03 PM
    Aw9d
    Aw9d That one guy
    Thanks for this info. I'm getting ready to swap my parents bumpers around on their trucks this weekend and this will come in handy.
  15. Mar 15, 2012 at 7:41 PM
    KornSanDiego
    KornSanDiego Well-Known Member
    Washington
    2016 Tacoma TRD 4x4 Sport
    Clazzio's, N-FAb w2w nerf bars, oem tonneau, JBL, custom bedside decals, led interiors, mudguards, exhaust tip, bed mat, mud guards, all weather liners
    dude, i just plasti dipped my bumper and grill. Best 6 dollars I have ever spent
  16. Mar 15, 2012 at 7:50 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Did you remove the bumper or just tape it off?
  17. Mar 15, 2012 at 7:56 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Probably take it off. Everything on the Tacomas are really easy to work with (in my experience) that would herald the best results too.
  18. Mar 15, 2012 at 8:52 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I'm just lazy and heard they were fairly heavy!
  19. Mar 15, 2012 at 9:34 PM
    Darth_Yota
    Cam-moron
    Somewhere USA
    Awkward to move around (if space is an issue) but not too heavy. Good weekend project for sure
  20. Mar 15, 2012 at 9:48 PM
    hitmans.army
    Myrtle Creek, OR
    Depending if I will be working on my buds vette this weekend, I might take my rear bumper off and give it a few coats of Rustoleum bed liner, along with a couple more on the front bumper.
