Surface Rust Cleanup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpicyYodasTacos, Sep 13, 2021.
  1. Sep 13, 2021 at 6:33 PM
    SpicyYodasTacos
    SpicyYodasTacos [OP] Member
    2016 TRD Offroad Access Cab - Black
    I plan to clear the surface rust from my frame and rear axle. Afterward I plan to paint with rustoleum paint for farm equipment.
    I know I want to avoid chemicals and oils from getting on the brakes. Also, I'll tape off the exhaust components. Are there any other big no-no's I should be aware of?
  2. Sep 13, 2021 at 7:45 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Brush off dirt, Rattle-can rust reformer, rattle-can top coat. Reapply annually as needed.
    Or just do an annual application of Fluid Film or equivalent.
  3. Sep 13, 2021 at 7:54 PM
    SpicyYodasTacos
    Clean up and paint over nuts and bolts or no?
    Tape off all bushings?
  4. Sep 13, 2021 at 9:18 PM
    CT Yankee
    CT
    Cleaning paint off threaded fasteners is typically easier than trying to loosen corroded fasteners.
    SpicyYodasTacos[OP] likes this.
  5. Sep 14, 2021 at 6:58 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd just wire brush any surface rust scale if there is, then apply the rustoleum rust converter. Once dry rustoleum black paint. Cosmoline rp342 for the final finish.
