Surface rust on trailer hitch receiver
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hank_Mille, Oct 17, 2024.
  1. Oct 17, 2024 at 8:31 AM
    Hank_Mille
    Hank_Mille [OP] Well-Known Member
    PNW
    2016 Tacoma Limited
    What's the best way to address rust on the trailer hitch receiver?
    I assume using a wire brush wheel on a chordless drill to remove all the rust, then apply a solid coat of Rust-oleum spray paint?
    TIA
    :cheers:
  2. Oct 17, 2024 at 8:52 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Yep.
    blak shinobi2 likes this.
  3. Oct 17, 2024 at 8:55 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I’ve been there. I did exactly what you described. I know this isn’t that helpful without a before pic but:
    I used “rust tough” and it matched perfect, looked great, but the rust came back after a year in some spots, albeit much lighter.
    I generally prefer Krylon for application consistency. It’s probably operator error, but I get fewer runs using it vs other brands.
    I’ve switched to “rust reformer” from rustoleum for rusty crap though. Hasn’t been long enough to know if it’s better than the Krylon, but I’m hopeful.
    It’s worth noting that rust-oleum is just the brand name. It doesn’t do anything special the other brands don’t, unless you pick one of their products with special claims
    https://www.homedepot.com/p/Rust-Ol...ormer-Flat-Black-Spray-Paint-248658/202623091
    AK Dudeman likes this.
  4. Oct 17, 2024 at 9:10 AM
    musicisevil
    Alaska
    2019 TRD Sport
  5. Oct 17, 2024 at 9:19 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Prevent =/= convert
    Thanks for sharing your experience with it
    blak shinobi2[QUOTED] likes this.
