Surface Rust Suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by CS_AR, May 13, 2019.
  1. May 13, 2019 at 7:09 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    One thing I just thought of is that Tractor Supply sells "Farm Implement Paint" That has a hardener that can be mixed with it toughening it. That may work ,applied by brush. Those hardeners are toxic to spray though so beware.
    GQ7227 and CS_AR[OP] like this.
  2. May 13, 2019 at 7:12 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Yeah, earlier I brushed on a van sickle implement paint in my bed. I put the hardener in the paint according to the instructions, but it doesn't seem to have done much. It scratches down to the primer very easily, but the primer seems to be rock hard. My only guess is maybe it was too humid or something. I need to get that sorted out before I try more painting though, its really annoying. Thanks for the tip though.
    CS_AR[OP] likes this.
  3. May 13, 2019 at 7:20 PM
    Troyken
    NY
    Weather plays a huge role in the success of a good paint job. My neighbor did a driveway paint job on his truck with acrylic enamel and hardener a few summers back. He set everything up the night before and the next morning came hot and dry. He had mid temp reducer. I advised him to get retarder or high temp reducer. He declined and got the worst orange peel you have ever seen as a result. He wet sanded the truck so much to get it out that you can see the primer in spots. Hot weather and humidity will cause major problems. Proper reduction of materials is also key in getting a good job. Measure, don't eyeball. Not implying you didn't....
    CS_AR[OP] and 0xDEADBEEF like this.
  4. May 13, 2019 at 7:23 PM
    0xDEADBEEF
    I bet thats got something to do with it. I measured...with a soup can. Was it the 15th line up or the 17th? :anonymous: Next time shall be better. Could I do it by weight maybe?
  5. May 13, 2019 at 7:23 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Damn you southerners and your lack of road salt!
    Spend some time washing the underside real good, anywhere dirt and shit can get trapped / accumulate. Then let it dry and coat everything with fluid film. Get the 360 degree spray wand thing (comes as part of the full spray kit or separately) and focus on the nooks, inside the boxed sections of the frame etc. Re-apply as needed or yearly
  6. May 13, 2019 at 7:26 PM
    Troyken
    NY
    I always use the measured cups from the auto body supply. I think Home Depot has them too.They make it easy and accurate. You can weigh too. That was how they mixed paint way back. Good Luck, I hope it comes out better next time.
    CS_AR[OP] and 0xDEADBEEF[QUOTED] like this.
  7. May 13, 2019 at 8:18 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i still need to talk to the owner of the shop to see exactly how they paint the inside and seal it up
    so what are the folks up north in the winter states supposed to do when they go buy a used truck from the south(east) or west coast that has not been undercoated since day 1 before it left the lot?
    CS_AR[QUOTED][OP] likes this.
  8. May 13, 2019 at 8:23 PM
    CS_AR
    CS_AR [OP] Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Take it home and get it undercoated.
    Emmetjmcc4 and GQ7227[QUOTED] like this.
  9. May 13, 2019 at 8:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    but the rust has already started? from water splashing on the untreated surfaces underneath?
    i still dont know all that much about this
  10. May 13, 2019 at 8:26 PM
    0xDEADBEEF
    Clean up the rust, treat it with ospho, paint it, then thin film it annually. I wouldn't bother with powder coat - once it bubbles up its a pain to repair. Paint you can touch up easily.
    cruiserguy and GQ7227 like this.
  11. May 13, 2019 at 8:27 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i don't know much about powdercoat, I thought it was a fairly permanent seal, to cut out ALL oxidation, which is the only way rust spreads?
  12. May 13, 2019 at 8:29 PM
    0xDEADBEEF
    Its permanent until it gets a defect in it, a small hole, a scratch, etc. Then oxidation gets under it and it spreads under the powder coat and eventually the coating peels off, leaving a layer of rust underneath.
    At least, thats been my experience with it. Many hours spent grinding on a trailer last summer so I could paint it after the powdercoat failed.
    GQ7227[QUOTED] likes this.
  13. May 13, 2019 at 8:35 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the stuff should be thick enough to not scratch or chip they told me, i dont know, they bake it really hot
    I mean they do powdercoat on wheels and those would look nasty all chipped up
    I will double check tomorrow, I am having them sandblast and powdercoat my lower shield on the fuel tank
    0xDEADBEEF[QUOTED] likes this.
  14. May 13, 2019 at 8:40 PM
    0xDEADBEEF
    It could very well be that I've only dealt with shitty powder coat. :annoyed:
    GQ7227 likes this.
  15. May 13, 2019 at 8:47 PM
    #35
    GQ7227
    GQ7227 mw survivor
    J A Y
    i am going to ask them a million and one ?s
    http://trailperformance.com/
    that is their website, they do classic cars and motorcycles, dragsters
    they were highly recommended by my local bodyshop
    1st shop that I feel actually took an interest in my situation
  16. May 13, 2019 at 8:53 PM
    #36
    GQ7227
    GQ7227 mw survivor
    J A Y
    well they dont get the fun and excitement of 4wheeling in deep snow and slushy ice :D
    SR-71A[QUOTED] likes this.
  17. May 13, 2019 at 9:12 PM
    #37
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Look up Awl-Grip paint, used to be the hardest urethane paint made.
  18. May 16, 2019 at 6:43 AM
    #38
    GQ7227
    GQ7227 mw survivor
    J A Y
    not sure what you mean by hard time?
    the proprietor told me he powdercoats inner frames often and does not see potential problems, it seals it up so no oxygen gets to it which any rust needs to thrive :notsure:
    the improved technologies has made this paint/procedure very durable and about the only thing that would hurt it/scrape it is dragging the frame across a boulder or something like that.
    i am an amateur and just trying to learn and weigh the options available
  19. May 16, 2019 at 6:59 AM
    #39
    GQ7227
    GQ7227 mw survivor
    J A Y
    i wonder why they don't?
    you have gravel roads?
    it rains? humid?
    "Cold Climate States: District of Columbia (DC), CT, DE, IL, IN, KY, MA, MD, ME, MI, MN, NH, NJ, NY, OH, PA, RI, VA, VT, WI, & WV."
    is your state on this list?
    mine is not for some reason (nor is Iowa which borders MN,WI,IL which are on the list) yet we get a fair amount of snow and ice in the winter, over 2ft of snow here in February, snowed every Saturday! and they put the nasty de-ice stuff down every damn time
  20. May 16, 2019 at 8:35 AM
    #40
    cruxofthebisquit
    Orange Texas
    2000 TRD
    road sand/fine dirt and dust blasting it for 20 yrs.
    Mine looked the same when right after i started parking it. Stayed pretty blasted looking as long as it was my daily.
    I brushed it and re primed. Funny they don't make replacement (safety caps) front horns. I could see that rusting if not kept after.
