Surfing & Key Fob
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tundraconvert, Nov 21, 2017.
  1. Nov 21, 2017 at 8:39 AM
    tundraconvert
    tundraconvert [OP] Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    Can I get some suggestions as to what you guys do with the key fob while surfing?
    I used to just take my key with me but now there is the fob. I tried taking the key out and putting the fob in the console but that doesn't work. I'm new to the "new car"technology.
    Thanks.
  2. Nov 21, 2017 at 8:40 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Hide somewhere under the truck
    El Duderino likes this.
  3. Nov 21, 2017 at 8:41 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    What do you mean it doesn't work? It absolutely works. You take out the side key. Leave the fob in the truck. Lock the door with the key and take it with you.
  4. Nov 21, 2017 at 8:42 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    probably means the truck wont lock with the fob in the truck? idk if it works that way or not. just my first thought
  5. Nov 21, 2017 at 8:45 AM
    uhplifted
    Brian
    16 DCLB OR
    It definitely locks with the fob inside. I've done it multiple times with the truck still running (because it was hot AF and my dog was inside while I went to go pick up a to-go order, and left the AC on full blast) and other times with the truck off.
    GPsevinSixx and ODNAREM like this.
  6. Nov 21, 2017 at 8:58 AM
    tundraconvert
    Eric
    San Diego
    yes, this.
    like I said I have not ever had a fob, reading up on a lot of different ways now. I wanted to get in the water this morning since I Have the day off and needed a quick fix.
    I ordered the little key bag that disables signal. Going to try aluminum foil now.
  7. Nov 21, 2017 at 9:03 AM
    tundraconvert
    Eric
    San Diego
    I figured it out, thanks for feedback.
    Pella likes this.
  8. Nov 21, 2017 at 9:45 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
  9. Nov 21, 2017 at 10:46 AM
    Pikestaco
    Pikestaco Newbie
    Los Angeles
    2017 Quicksand 4x4 TRD Sport DCLB
    need to learn more about this stuff
    i have a tonneau cover. i put it in the bed and then lock the bed.
    but you can put the fob in the cab, but instead of locking the cab with the fob button, you lock it manually with the key you pulled out of the fob.
    any good waves down there? small kine in LA.
  10. Nov 21, 2017 at 10:51 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    OP You're doing it wrong if you can't lock the truck with the fob inside. I surf almost everyday and I always take the key out of the fob, put the fob in the glovebox, lock the truck via driver's door keyhole and put the key in my wetsuit.
    DONT hide the key under your truck like a kook, thieves watch surf parking lots for people doing exactly that.
    No need to get tin foil or special bag for the fob either if you lock the truck manually with the key it will ignore the FOB signal.
  11. Nov 21, 2017 at 11:04 AM
    tedburgundy
    tedburgundy Well-Known Member
    I put my fob inside lockbox in the cab, that way if they break in they can’t just start the truck. Lined lockbox with foil and no signal gets out.
    Ted
  12. Nov 21, 2017 at 12:18 PM
    tundraconvert
    Eric
    San Diego
    Thanks.
    No it’s small but better to get wet than not.
    For some reason it wouldn’t let the first couple of times I tried. Now I can lock fob in truck and just take key.
  13. Nov 21, 2017 at 1:15 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Did you know that you can turn off the FOB..?? You have to hold the lock/unlock buttons for a few seconds or so....!! (IT'S IN THE MANUAL).. Then hide it in the truck... take the key and lock truck...put key in swimming trunks (that is, IF you are wearing any)...if not put on a string around yer neck...hehe
    tundraconvert[OP] likes this.
  14. Nov 21, 2017 at 1:20 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Yep, this is what I do, you can deactivate your FOB and leave it in the truck then just slide the mini key out and wear it around your neck. I made a pretty cool necklace with it and wear it underneath my wetsuit. With the FOB deactivated you just lock your rig the old fashion way w the key.
  15. Nov 21, 2017 at 1:34 PM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Here is the page from the manual to use the battery save function.
    Pull the removable key out, activate battery save function, put the fob somewhere hidden in your truck, push the lock button on the inside of your door, close door. take the key with you.
    over60 likes this.
  16. Nov 21, 2017 at 1:40 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Know I’m just lost where do you plug in the mini on the door?
  17. Nov 21, 2017 at 1:45 PM
    wirenut
    Andrew
    NH
    98’ T4R
    Yup just looked, never noticed a key slot on the door handle or the bed
  18. Nov 21, 2017 at 1:52 PM
    over60
    Muskoka, Ontario
    I guess you are screwed...Musta been made in Mexico....they put the keyed door handle on the right side, I'd bet....
    Better check the passenger side....!
  19. Nov 21, 2017 at 2:25 PM
    wirenut
    Andrew
    NH
    98’ T4R
    Oh it exists where it should. I just never noticed them.
    over60[QUOTED] likes this.
  20. Nov 29, 2017 at 12:46 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ok, so just hiding a active keyfob won’t prevent all thefts!! Make sure it’s turned off to disable it when storing it using the key press method described in the earlier post.
    But with the battery saving mode enabled, it appears it will be harder for crooks to do a “relay theft” (using a separate radio near the front door of the owners house or anywhere near a stashed keyfob to pick up and repeat the keyfob signal back to the car to steal it).
    Does the Tacoma have a cutoff switch as a Prius does under its dash to disable keyless entry too? That would stop “relay theft” but will also be handy when remote parking for a hike or something where the truck is alone and someone uses a scanning device or even your lost keyfob. If not, anyone know how to install one?
