Surge then RPM's drop to about 200
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, Oct 23, 2013.
  1. Oct 23, 2013 at 1:07 PM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Here's one for ya. When I come up to a stop light, sometimes the RPM's will surge up to about 800 then they quickly drop to about 300. The engine doesn't stall but I do have to push the pedal to keep it running. Any ideas?
  2. Oct 23, 2013 at 10:43 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    O2 Sensor may be bad. Could be sending false readings thus affecting idle. Had that happen to me. I find that when I have had idle issues in the past its usually a sensor issue. MAF, O2,...something. Could be a fuel filter though it usually sputters and dies.
  3. Oct 23, 2013 at 10:45 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Throwing any codes?
    Fuel pressure switch, fuel pump, fuel filter, dirty air filter, misfire at idle, bad alt, bad mad, list goes a on
  4. Oct 23, 2013 at 11:03 PM
    PhdNPrerunners
    PhdNPrerunners Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    Also might want to check your idle Air control valve. My truck does the same thing sometimes but I just haven't got around to replacing it.
  5. Oct 23, 2013 at 11:09 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Running lean, and even rich is crazy bad for your engine.....
  6. Oct 24, 2013 at 7:36 AM
    PhdNPrerunners
    Justin
    The Woodlands, TX
    Ya I know that why I haven't been driving it. I've been trying to order it off of a couple of Toyota websites but when I search for the part it never comes up
  7. Oct 24, 2013 at 7:40 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    This^ it happened on my old Ranger. Does ur trucks rpm shoot up to like 2k when u start the truck? Or just at stop lights?
  8. Oct 24, 2013 at 9:51 AM
    PhdNPrerunners
    Justin
    The Woodlands, TX
    No the rpms just up to 1200 when I first start it up but drop down to 1000 till it warms up. Sometimes when I am at a light the rms will drop to 500
  9. Oct 24, 2013 at 11:40 AM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Today at lunch it idled at about 2000 when I first started it. No codes are being thrown.
