Surging and dropping RPMs 2.7L
Discussion in 'Technical Chat' started by Skittles93, Jun 26, 2018.
  1. Jun 26, 2018 at 11:38 PM
    Skittles93
    Skittles93 [OP] 'Member
    Novato CA
    TRD OR SB 4x4 (sold) 19 4runner TRD Pro
    Frankenstein Mid-Travel Kit, sPod, Relentless Custom Baja Bumper, Relentless: Sliders, T-case skid, rear bumper, tailgate reinforcement, Rago Fab: Bed Channel Stiffeners, SCS 16" wheels, BFG KO2 275,75,R16, Diff breather mod, A/C hose extension mod, Custom exhaust routing. (Sold)
    Hey all,
    Ive been looking all over for someone with the same issues and I cant seem to find any. Anywho I have a 2012 2.7L 4x4 4 speed with 150K. I was driving through a pasture today and starting notice the trucks tach surging and dipping from 1000 RPM to 1400 with constant throttle pressure, confirmed on the road on even ground. It didnt do this in 4th gear only around 20mph or so in 3rd/ 2nd. Any thoughts? Idles fine. No MILs. Serviced 1,000 miles ago so oil level should be fine. Thanks for your input!
  2. Jul 2, 2018 at 6:23 AM
    tacoma4
    tacoma4 Well-Known Member
    Could be many things. First thoughts are MAF or TPS. Have a scanner where you can view data?
    Skittles93[OP] likes this.
  3. Jul 4, 2018 at 9:46 PM
    Skittles93
    Novato CA
    I ran it through a scanner and nothings there. I ran some MAF cleaner through recently enough. I’ll bet it’s TPS, I hadn’t thought of that. Or maybe a vacuum line leak?
  4. Jul 5, 2018 at 9:17 AM
    tacoma4
    What kind of scanner are you using? Most allow you to view live data while driving. Should be able to see if the TPS has a bad spot in it just sitting still, slowly depress the pedal and the reading should go from 0-100% in conjunction with pedal position. Can do this with engine off so you aren't revving the engine. MAF you can watch flow rates for anomalies. Vacuum leak would show up in your fuel trim data if it is intermittent, then you will see the short term fuel trim changing around when you have problems. If it's constant, it will show up as a change in the long term.
  5. Jul 5, 2018 at 10:00 PM
    Skittles93
    Novato CA
    I have a scangauge II, so its not that fancy. I will try reading the gauge with the TPS and scangauge, I know I have the TPS percent gauge, I didnt know it worked when in ACC. Thanks!
