Surging engine - Any ideas???
Discussion in '1st Gen. Tacomas (1995-2004)' started by woodygg, Apr 12, 2018.
  1. Apr 12, 2018 at 3:23 PM
    woodygg
    woodygg [OP] Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    So my 2004 3.4L started surging the other day. During mid-band, under acceleration I noticed a subtle surge in the engine (surging up and down constantly), until I backed off the gas. Well over the course of a few miles it got quickly worse - surging more and more at lower and lower speeds. Right before I pulled over, even when I floored it - it would make the lower guttural sound the Taco's do, but it was like it wasn't getting much gas.
    Have about 80K miles on it - it's an automatic - been running perfect since I've had it the last few years.
    I love my mechanic who has worked on Toyota's for 30 years or so - but after the first day they're having a problem figuring out what it is.
    Any thoughts? Thanks!
  2. Apr 13, 2018 at 8:52 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Try cleaning the MAF first. No code?
  3. Apr 13, 2018 at 9:07 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    IAC (Idle air control) valve maybe?
  4. Apr 14, 2018 at 7:10 AM
    Glamisman
    Glamisman Well-Known Member
    is it a "drive by wire" throttle by chance?
  5. Apr 14, 2018 at 7:18 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    This? Had the same problem wit a 97 Acura. Replaced the IAC, problem solved.
  6. Apr 15, 2018 at 12:41 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Still checking, will look at these - thanks!!
  7. Apr 15, 2018 at 12:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The previous owner of my truck said he replaced the fuel pump because it was surging, and that fixed it. That was on a gen 2 but seems universal.
    cruxofthebisquit likes this.
  8. Apr 15, 2018 at 7:05 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yes, work your towards that as most of these problems have that behavior w/o throwing codes.
    EDIT: You'll eventually start getting a 'lean' code from these but by then you may have pulled out all of your hair.
  9. Apr 16, 2018 at 6:27 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Under what conditions does it still surge now? Does it surge at idle and under power or only at specific rpms? Knowing that will help you start to look for problems.
  10. Apr 16, 2018 at 10:08 AM
    crankpin
    crankpin Well-Known Member
    Crank
    Florida
    2003 PreRunner
    I'm not a mechanic. PCV valve, the molded hose, grommet, etc., all good ?
    Below from a mechanics forum, for Lexus, Toyota, etc.
    If the PCV system is not functioning properly, the flow of crankcase vapor into the intake manifold will not be correctly metered. This, in turn, will upset the fuel/air mixture for combustion and can cause rough idling or even stalling of the engine. Furthermore, intake and exhaust valves, in addition to sparking plugs, may eventually be burned and rendered useless, prematurely affecting performance and requiring expensive repairs. To assure trouble-free performance of the PCV system and, in turn, the engine and vehicle, routine maintenance of the PCV system are recommended and required.
  11. Apr 18, 2018 at 8:33 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    It has good fuel pressure, etc. Not sure why the IAC would affect anything above idle?
    Dalandser likes this.
  12. Apr 18, 2018 at 3:58 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Well just found out the catalytic converter is bad - that was a big problem. Being replaced hopefully that was it - my mechanic is baffled as it didn't throw and codes - he'd never seen that happen before. Will see if that clears it all up.
  13. Apr 18, 2018 at 4:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I've see a couple of these on the YouTube mechanic's channel I like to watch, South Main Auto. Same thing - no power at high rpm's, idles great, no codes, but engine chokes and sputters from all the back pressure at higher rpms. He even had one like yours where it happened all of a sudden when someone was driving down the highway. He said the cat material can ball up and all of a sudden let go and get stuck in the exit end. He was able to diagnose it by doing a relative pressure test and see that the pressure in the cylinders on the exhaust stroke never went down to atmospheric.
  14. Apr 19, 2018 at 9:03 AM
    SalemCBR
    SalemCBR Oregon's #2 TW rep
    Oregon
    04 DC Elock PreR
    Deck plate, all time auxillary, black billet, xeon bulbs, sockmonkey decals, and lots of back to black.
    I am not throwing codes. Having a surging at idle and everywhere else. Surges faster as I accelerate. Replaced throttle body, no change, did plugs n wires cleaned maf.
    So your cat being bad caused this??
    woodygg[OP] likes this.
  15. Apr 19, 2018 at 9:04 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah, but he wasn't idling rough.
  16. Apr 19, 2018 at 9:08 AM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Hmm. I am not running rough as much as pulsing type throttle once the engine starts to warm. Takes 40 seconds or so. At idle its like 200-300 rpms. Not sure what to do next.
  17. Apr 19, 2018 at 9:20 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It's idling that low? It should be 7-800 rpm. If there's no codes you can check to see if you have a cylinder that's not firing / making power by unplugging one spark plug at a time and seeing if that makes a difference. The cylinder that doesn't change how the engine is running will be the one that is misfiring if it feels like a single cylinder misfire.
    Other than that, cleaning the MAF is a cheap solution that could cause rough running at all rpms.
  18. Apr 19, 2018 at 9:25 AM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Sorry, I meant the idle fluctuates 2-300 rpms every 1.5 seconds or so. The idle is at about 800. I have cleaned the MAF a few times. Surging is much more noticeable when under power.
  19. Apr 19, 2018 at 9:48 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Depending on how much experience you have, the maf can be tested to see if it's sending a good signal. You can test to see if the cat is plugged by doing a leakdown test or even just blowing compressed air a cylinder in the exhaust stroke and seeing if it blows through cleanly.
  20. Apr 20, 2018 at 11:50 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Turns out it was just the cc... mechanic had never seen that happen before - run like that anyway, no have it not throw a code when it was. Thanks everyone for the suggestions, etc!
