Surging engine - Any ideas???
Discussion in '1st Gen. Tacomas (1995-2004)' started by woodygg, Apr 12, 2018.
  1. Apr 20, 2018 at 12:15 PM
    Glamisman
    Glamisman Well-Known Member
    the tech not seeing any codes for the cat being bad kind of makes sense... I dont think you gave it enought time to generate a CEL, if any. There is no check for a plugged cat, just one that doesnt function right.
  2. Apr 20, 2018 at 12:43 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Well there's an 02 sensor before the cat and an 02 sensor after the cat which measures the difference in airflow through the cat. The difference in flow can be enough to trigger a CEL.
    Also when diagnosing on some other vehicles, you can run a vaccum gauge on the cat to test its effectiveness.
    I've always used a IR tempature gun to check the temps.
