Surging/Thrusting Problem Under Acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by jberry813, Jan 2, 2013.
  1. Jan 15, 2013 at 4:45 PM
    #181
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I would try another "known good" ECM. In other words a brain from a "good running" truck. [​IMG]
  2. Jan 15, 2013 at 4:54 PM
    #182
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Considering I'm having difficulty finding someone close enough to borrow a coil pack from (and the same coil is used in like 50 different models of toyotas), finding a ECM for the same truck (4x4, 5 speed manual, 3.4, ETCS-i TB) is going to be even harder.
  3. Jan 15, 2013 at 5:06 PM
    #183
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    $375 + $50 core charge. NAPA # NEC XTP21880 seems to be it if you go reman.
  4. Jan 15, 2013 at 5:13 PM
    #184
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I can pick up a used one for $100 off car-part, but it's still just a guess.
  5. Jan 15, 2013 at 5:36 PM
    #185
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Dude sounds like if he's wrong, you don't pay.
  6. Jan 15, 2013 at 9:45 PM
    #186
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ok....so what does it mean when I touch the outside of a spark plug wire while the truck is running, move it around a little bit to make sure its seated and what not....and it shocks the shit out of me? And then to make sure I didn't imagine it....i try it again and after a few more wiggles it shocks me again :anonymous:
    Again...only touched the outside of the plug wire. No lifting or pulling, just compressing.
  7. Jan 15, 2013 at 9:53 PM
    #187
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Is the shock coming through the insulation on the wire or is it coming from the plug/some other metal part? It could be that in compressing the wire you are getting closer to something metal and that's where it's coming from.
    Sounds crazy, though!
  8. Jan 15, 2013 at 9:55 PM
    #188
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    wires are pouched.
  9. Jan 15, 2013 at 10:04 PM
    #189
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Only touched the insulated wire, nothing else.
    Guess I'll pick up a new set.
  10. Jan 15, 2013 at 10:06 PM
    #190
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Could this be your problem? I don't remember if it was ruled out
  11. Jan 15, 2013 at 10:11 PM
    #191
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Could be.
    I replaced the wires when I put this engine in the truck so they have only 20k on them. I visually inspected them and tested the resistance and they measured within spec according to the FSM. But if a wire is shocking me when I touch it, it certainly could be grounding out during spark and account for a lean surge.
  12. Jan 15, 2013 at 10:18 PM
    #192
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Fingers crossed!
  13. Jan 15, 2013 at 10:29 PM
    #193
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Be nice if that really was the answer. $30 will tell you.
  14. Jan 16, 2013 at 5:38 AM
    #194
    BamaToy1997
    Bill
    Navarre, FL
    I do admit it would not be unusual if that is your problem. You should NEVER feel a shock when you are touching a wire. All the diagnosis we have been working on so far has been by your replacement of parts you had mentioned, and the assumption that they are working properly. lol. No way of being able to tell if they are bad. That is one of the reasons it sucks with a difficult problem with not having the truck. I have one of those big ass OBDII scanners at my shop here, and it is worth it's weight in gold. If you do have one of your new plug wires leaking secondary spark, then under load it could DEFINITELY cause a lack of power, and may be perceived as a surge. Man I had hoped that the FPR would have been the problem. I think that is the first part I have suggested to replace. I didn't mention a Tundra because I didn't know you HAD a Tundra, and to be honest, I wouldn't have known they had the same FPR unless I looked up part numbers. At least now we have that issue out of the way. You wouldn't happen to have a GoPro on you? I am thinking at night you could mount it under the hood, pointed at the engine. Then, when driving at night, and under load, you could look for signs of arcing.....
    WOW, Just after typing that statement made me think of a possible thing. EMI! Check the routing of your plug wires. If they are ANYWHERE close to the harnesses that runs in the engine bay, and the plug wires ARE "leaking" spark, they could induce EMI into all sorts of sensor signal wires. If you shock yourself at idle, imagine what the leakage is when under load at 2500 RPM? Since you DO shock yourself, I would replace the plug wires anyway, period. Get a decent set and make sure that you lock them in good. Even if that is NOT your real problem, you should replace those wires.
  15. Jan 16, 2013 at 7:17 AM
    #195
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    oh dang!! the gremlin may have shown his face...ive had this happen on a piece of equipment before. small tiny tear in the boot and it was arcing to the block every once in a while. Hopefully this solves the issues
  16. Jan 16, 2013 at 8:03 AM
    #196
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    I had that thought, as well.
    Another thought, I had my engine mounts fail after about 18 years (170,000 miles), which caused the engine to sag into the radiator a little bit but only when the truck tilted forwards. Perhaps 2500rpm and sagging engine mounts could cause the engine to move in some way that the plug wires get close enough to something to arc, hence only causing the problem at a medium load. I realize your truck is not as old as mine and I don't know if this is feasible at all, but given the jumping hits it has taken I think it'd be easy enough to check.
  17. Jan 16, 2013 at 8:10 AM
    #197
    dirty dangler
    adam
    simi valley,ca
    jason upgraded to solid motor mounts awhile back
  18. Jan 16, 2013 at 8:12 AM
    #198
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Ah, well then that rules that out
  19. Jan 16, 2013 at 8:52 AM
    #199
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Wasn't referring to you, just in general. It was one of those opiphany moments when I remembered Toyota isn't very creative and they reuse the same designs over and over in different vehicles. The FPR is not the same, but the parts that count are the same. I had to mount he FPR upside down, but it worked for my purposes (test) and it's damn simple to pull off on the Tundra.
    I don't :(. I actually did a blackout opps last night with a spray bottle looking for arcs. Couldn't see any but I'm still replacing all the plug wires. Either way, Tyler (GreenTaco28) is coming down from Reno to help swap parts around until the surging stops! At this point I'm not taking any chances, I'll swap wires and if that fixes it, great, I'll order just the wires. If it doesn't than I'll move on to coils and work from there.
    I will shoot a gremlin on site at this point!
    I downgraded back to factory mounts till I cage it, but the downgrade was after the surging started. :anonymous:
    Get a new phone...you know I keep you in the loop!
  20. Jan 16, 2013 at 2:30 PM
    #200
    BamaToy1997
    Bill
    Navarre, FL
    I hate when I see a problem with a truck and I can't get my hands on the truck to run my tests! GRRR....Let me know what you find when he arrives.
