Surging/Thrusting Problem Under Acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by jberry813, Jan 2, 2013.
  1. Jan 20, 2014 at 4:43 PM
    #241
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Have you eliminated the fuel pump/pickup?
  2. Jan 20, 2014 at 4:45 PM
    #242
    I4anI
    I4anI Member
    Mark
    Houston, TX
    TRD s/c, URD 2.85 pulley, CAI, magnaflow cats back, JBA longtubes, Unichip W/flux2, Level10 valve body, Walbro 255 fuel pump, fiberwerx prerunner fenders, bi xenon heads and fogs, 2 12" LED bars
    its a brand new walbro 255… 3 months old, tops
  3. Jan 20, 2014 at 4:48 PM
    #243
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ive been in SC 2nd gen and that's def not normal. When you get on it, it gets going. Unless your leafs cant handle the power. Im thinking axel wrap/wheel hop is the issue here. Traction bars will do wonders for you im guessing :D.
    And Procomp uses lift blocks in a lot of their kits. Blocks make it worse.
  4. Jan 21, 2014 at 2:58 PM
    #244
    I4anI
    I4anI Member
    Mark
    Houston, TX
    i sent my valve body off to level 10 to be modified… is it possible it could be the valve body not working properly causing my surges and whatnot? almost like its getting caught between gears. valves not opening and closing at the proper moments? i might be talking outta my ass, but i gotta figure out what the hells going on...
    Luv my yota likes this.
  5. Dec 3, 2014 at 3:53 AM
    #245
    j00h
    j00h Member
    SF Bay Area
    02 Tacoma TRD 4x4
    My 2002 TRD Tacoma V6 with supercharger was having surging under load only during closed loop operation as well and seemingly occurring around 3k rpm. I somehow stumbled on this thread...
    I took a look at the cats and found the front cat honeycomb had sperated from the body and crushed about 2\3 area from the end of honeycomb where the cat necked down. New cat and surging is gone. Seat of the pants also make me think I got more power!
  6. May 2, 2018 at 10:14 AM
    #246
    Heavydutydan
    Heavydutydan Member
    2002 Tacoma TRD
    Don't mean to necro-post..lol.. But my truck started having the exact issue the OP posted, and thanks to this thread, I'm gonna start with the cat.. It's an '02 with all original exhaust, 162,000 miles, so I think it's safe to say the CC has had it. I'll update after the repair to further help others who will eventually experience the same. Cheers.
  7. May 2, 2018 at 10:15 AM
    #247
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Definitely necro!
    If ya unbolt the exaust it may be loud as hell, but you will know real quick if the cat is the problem.
    DoorDing likes this.
  8. May 2, 2018 at 10:22 AM
    #248
    Heavydutydan
    Heavydutydan Member
    2002 Tacoma TRD
    Thanks! I'll try that. I have some other stuff to deal with first (Time for a timing belt!) and gonna install some new coilovers I just picked up. I see you've since moved on from your first gen and on to a second gen (or maybe you have two?) Thanks again for the post and information. This is why forums are awesome!
  9. Jul 31, 2018 at 4:25 PM
    #249
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    Any updates, just got an 01 and started doing this
  10. Jul 31, 2018 at 4:26 PM
    #250
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Exactly what update are you looking for? Issue was resolved.
  11. Jul 31, 2018 at 4:29 PM
    #251
    defythemall
    San diego
    I meant the dude above my post
  12. Jun 20, 2019 at 11:51 PM
    #252
    Samzmurchyk
    Samzmurchyk Well-Known Member
    Samuel
    2005 white Tacoma TRD 4.0l
    Stock
    I’m having a similar issue as OP. Truck surges going uphill (only at a certain throttle position) Ive checked vacuum leaks. No codes, I do have cats. Full throttle no problem it’s only at a certain throttle position while accelerating.
    Any information helps
    2005 Tacoma 4.0l
  13. Jun 21, 2019 at 9:36 AM
    #253
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Holy thread necro!
    If it is the same issue I had it’s an easy check. I would suggest just unbolting the exhaust after the first cats and go for a test drive. It will be loud af but easy test to see if the cats are clogged.
  14. Jun 21, 2019 at 9:41 AM
    #254
    Samzmurchyk
    Samuel
    Stock
    I knocked the cats out months ago because they were clogged. O2 sensors are good. The one behind the cat I have tricked so it doesn’t throw that code. It’s only at a certain throttle position during acceleration
    It has a k&n intake I’ve checked for leaks with carb clean.
    My fuel trim is high 8-15% long
    I don’t think it’s the fuel pump because when you romp on it it’ll go without a problem.
    Note: I have a high flow cat welded further back in the mid pipe.
    Edit: now that I’m thinking about it when I use cruise control when it has to accelerate it goes ape shit and shifts down super low to get up to speed. Like say you slow down to 80km and you had it set at 100km it’ll down shift to 4-5k rpm
    I’ll throw my old maf and order a tps
  15. Jun 21, 2019 at 9:41 PM
    #255
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    It does sound like the shift patterns are screwed, its Very possible level 10 gave you the stick, they did this to Gadget. There’s a company Gadget uses for auto trans racing applications and it’s in AUSTRALIA, Level 10 has screwed MANY customers I don’t trust their work. Call URD and ask Gadget he’ll tell ya who you can trust. The Debbie Downers that existed here years ago made him not post here anymore, that really sucks because he knows his shit. You could always get a full built auto transmission for high hp Supras they go for around 2k. I’m buying one when I get my charger and skipping the valve body upgrade ,it already has it and isn’t much more. Flush with a few atf changes it can help, if it doesn’t, I’d pull the valve body out again.
  16. Mar 19, 2020 at 12:59 AM
    #256
    ToyotaTod98
    ToyotaTod98 Well-Known Member
    Tod
    98 limited 4x4 excab white
    Lift ,wheels,micky tires, 4.56 front and rear locker.
    What's up guys? I've been reading this whole post and every other thread that it links you to. And realize it's been awhile since y'all were trying to run down this problem. But I think this is the best place to ask my question anyway, so I hope y'all will see it. My truck started surgeing today. Doest matter which speed or rpm. But I can be driving at (let's say 60) and with my foot steady on the pedal ( not pressing or releasing) my truck will pick up speed ,like up to 65. It will do it at slower speeds also. Now I was fighting with an irratic idle a couple weeks ago. I had replaced the TPS sensor about two months ago and didn't think that was it. But apparently it was . Cause I replaced it again two weeks ago and it cleared up. Now when I say erratic idle, I mean once it's warmed up to operating temp, I can start it and it might idle at 1000 RPM and the next time I start it it might be at 700 RPM. It's like it resets every time I start it. Every time , in-between 1200-700rpm. I heard a bad TPS would cause it to surge, but I just changed it two weeks ago. Now I did just read somewhere on this site that if you get a aftermarket TPS that it would only last a couple months. That would account for the first one I replaced two months ago. But this one was a Toyota TPS with the correct part number. But I did get it on eBay for 12 bucks. U think those are fake? And also I was flushing out my heater core the other day and might have gotten a little water on it? I put a plastic bag between the outlet and the TPS but noticed there was a little water on it. My truck is a 98 taco 3.4 with 235000. I did the plugs and wires from the Toyota dealership. Cause the plugs were on 15 bucks and wires were about 60. Did both them about two months ago. The first TPS threw a code but the next one didn't. So I don't look for the check engine light to come on when anything goes wrong, cause it don't. A week after I did the plugs, I was driving home from work 200round trip, and my truck started missing, it was raining and I had done the deck plate mod and forgot to put the lid on and thought I got water in it. Didn't do it on the way over, just started on the way back. And about halfway back it wouldn't hardly run. About 60 , and when I pushed the gas pedal down just a little more it would really miss. Then as I got almost home it started running better, but would still miss. When I got home I started in . I pulled my air box and filter ( I was alittle damp) and pulled plugs. #6 plug was ok but #3 was broke and #1 was broke. . U could spin the top and it would spin all the way through. The whole middle of the plug was detached. And not a dam light came on the whole time. So I don't rely on it all the time.Also did someone say that the denso plugs from the dealership were junk? They tried to tell me that I broke it putting it in. I call bullshit on that. It's definitely possible if you don't know what your doing or use an impact. Should I overpay for a New TPS from the dealership or the eBay ones that have the correct part number ,OK? It was raining this morning and it didn't do it on the way over there, but started surgeing less than 5 mins as I started back home. But the first thing I did this morning was put the deck lid on. After reading all of this ,I'll look at my wires and make sure I don't have a short. I know they are crossing over each other but I made sure that they crossed where there was that extra insul. And I took out my plugs when I got home and they are ok. I went ahead and cleaned my MAF . WAS there a way to reset ur TPS? Did I read somewhere on this form that u could unplug it while ur truck was running, then shut it off and plug it back in? Where it would reset the TPS only. Unlike unplugging it battery to reset your ECU. Sorry so long guys. Just want y'all to get the whole pic. Let me know from experience what uve ran into?
  17. Mar 19, 2020 at 1:25 AM
    #257
    ToyotaTod98
    Tod
    Oh forgot to mention. I did think about it being bad gas. But when I filled up last night I also put in that marvel mystery stuff. Isn't that like seafoam, to where it would take the water out or atleast help it burn, if there was any bad gas? I got the truck about six months ago, and don't know about it's past, so every dime I can get I use it on pm for my truck, cause she's all I got. I've put 20000 miles on her and the only unforseen problem I've had was that it started to overheat about a month ago coming home. Had a bunch of rust in it. Saw that when I first got it and replaced the coolant, just didn't know how hard it was to get it all out. Cause two weeks ago it did it again almost in the same spot. I caught it before it got to the red. Pulled over and popped the cap and let it shoot all that rusty crap out. Pulled the thermostat and put water and casscade in , drove it home and spent 3 days of flushing and driving and flushing. Clean as a whistle now. That's why I was flushing the heater core now. I bypassed it for awhile to rule it out, while I was making sure it was a stopped up problem and not a head gasket. I had checked the water pump and changed the thermostat. And I wasn't loosing coolant. Also did that isle tester, for gas in the coolant. So I think I got that issue solved.Hopefully!! But I just can't stand it when something is not right. Especially when I'm a hundred miles from home, and usually broke to where I can't get a wrecker. And don't have anyone to call. So I got to keep her running good.
  18. Aug 25, 2022 at 2:58 PM
    #258
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    Yea my 03 surges on accell sometimes when i give it a good throttle. Betting it was the cats before i read this forum so points me back in that direction. Only shitty part is nee cats have gone up like 4 fold these days.. might just cut em out and get rid of em..
  19. Aug 26, 2022 at 6:39 AM
    #259
    ToyotaTod98
    Tod
    Yeah, your right, it definitely could be the cat, but it should throw a code if it was. I know that they dont always throw the 02 sensor, but most of the time it will. I took a long drill bit and drilled some holes down through mine so that it would flow good,and hoping it wouldn't throw a code and it worked perfectly and has been for two years. Of course this was before the big metal splurge. Cause now i would take it off and sale it before i just drilled it out. But since he didn't say anything about throwing a code, then im leaning towards fuel.
  20. Aug 27, 2022 at 1:45 PM
    #260
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    You know now that im thinking about fuel, ill be damned if i didnt put in most of a can of seafoam with only 1/8 a tank of gas and when i went to fill up i only put under a half tank in it because America and i bet that may have something to do with it.. im still on that same half a tank because i don't drive that far for anything ever so have had the surging for a while which made me not think about fuel. My old truck would drink the stuff so if it had bad gas itd fart it out in a half mile and be done with it.. im gonna go sell a kidney, give blood, sperm and whore myself out to fat chicks then put that money in a full tank then see if i still have issues, other than the mental trauma from the things i had to do to afford a full tank... :/
    but fyi you dont get a lot for cats really.. only for certain cars like prius or something with a big ass tri stage 100lb booger.. normally theyll only give you maybe 40 to 80 at most at the scrap yards unless you got one of the huge cats then youre looking at close to 300.. and plus nowadays you have to bring 2 forms of id, the registration or title of the vehicle it came off of plus if your in a gay state like california then they require a emissions recertification after the removal of the cats.. crazy over there.. luckily i live in Ky where you can strip down a car to frame and motor but as long as you got a seatbelt, lights and registration you can do what you want..
