Surging/Thrusting Problem Under Acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by jberry813, Jan 2, 2013.
  1. Jan 2, 2013 at 10:14 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Absolutely. Easier to pressure test.
    I would almost bet on a vacuum leak though. At least from the symptoms.
  2. Jan 2, 2013 at 10:16 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    vacuum leaks suck so much
  3. Jan 2, 2013 at 10:16 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Easy to test!
  4. Jan 2, 2013 at 10:17 PM
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Explain yourself.
    Do not make me post pooh bear ear pictures.....
  5. Jan 2, 2013 at 10:19 PM
    blake5995
    Blake
    Truckee, CA
    Get your hands on a fuel pressure gauge and just hook it up inline from the tank to the engine and then cycle the key.
  6. Jan 2, 2013 at 10:19 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Just spray a little carb cleaner around and listen to idle. You know that.
  7. Jan 2, 2013 at 10:20 PM
    blake5995
    Blake
    Truckee, CA
  8. Jan 2, 2013 at 10:24 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I lit my Miata on fire doing that....also chasing a vacuum leak. :anonymous:
  9. Jan 2, 2013 at 10:25 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Can you read the fuel trim? That might at least tell you if it's in the fuel system.
  10. Jan 2, 2013 at 10:27 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Shit happens!
  11. Jan 2, 2013 at 10:35 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    :turtleride: :pccoffee:
  12. Jan 2, 2013 at 10:38 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    You didnt mention it in the OP but are you dumping huge amounts of fuel? That may narrow down a misfire, fuel leak or injector failure. You could also get some fuel dye and dump it in your fuel tank and see if it comes out anywhere.
    My second thought like you is the MAF or maybe even the TB
  13. Jan 2, 2013 at 10:45 PM
    blake5995
    Blake
    Truckee, CA
    he already cleaned the TB and he is waiting on a MAF to try.
  14. Jan 2, 2013 at 10:54 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I know this. I was thinking it might be more mechanical
  15. Jan 2, 2013 at 11:01 PM
    #35
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    If it were MAF he should have. P0171 or P0174 off the top of the head. It will throw off fuel trim adaptions. Also if vacuum leak usually you get a 171 or lean code. Test the throttle body... Gut instinct. If its all electric it's basically a potentiometer. Either way I'd do a couple tanks with techron additive and marvel mystery oil added to fuel and see if it cleans injector pulse. Cheap, easy, non invasive, or BG 44k. I work with supercharged engines every day. Usually if there's power loss or stalling its TB related without throwing faults, or something inside your exhaust is falling apart or collapsing
    Darkyoda likes this.
  16. Jan 2, 2013 at 11:07 PM
    #36
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    My bet would be injectors. My buddies 2001 Tacoma had a messed up injector that would do what you're describing Jason. Only problem with that theory though is you would think it would be sounding and feeling more like a misfire.
  17. Jan 2, 2013 at 11:14 PM
    #37
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Fuck Jason if it's not one thing it another huh! That blows buddy, hope u figur it out soon and on the cheap :thumbsup:
  18. Jan 2, 2013 at 11:27 PM
    #38
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    or throwing a code
  19. Jan 3, 2013 at 12:28 AM
    #39
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Do us all a favor, put the motor back together and record the problem.
  20. Jan 3, 2013 at 12:37 AM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Shit dude. I hope you are getting some progress on this beast. Just looking at the list of everything you have done to it for replacement parts we would call that in the auto repair world, a "shotgun" lol.
    Honestly just thinking about the fact that the moment you pulled off the supercharger and the problem got better would lead me to believe you are having a fuel delivery problem. Which would send me straight to the filter and the pump. Next time something like this happens, I highly suggest checking for sufficient spark and proper fuel pressure first before you go any further. I wish you the best of luck if you haven't already fixed the problem.
    One more thought process to think about:
    Put everything back together, take it down to your local emissions inspection station and have them give you some manual readings of the vehicle. Any drivability issues you are having with the rig will rear its ugly head on there, from there I can assist you with pointing you in the right direction of what you should check that may be causing your issues.
