Surging/Thrusting Problem Under Acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by jberry813, Jan 2, 2013.
  1. Jan 3, 2013 at 12:45 AM
    #41
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    Dumb question have you switched they gas your using? (company/grade)
  2. Jan 3, 2013 at 12:54 AM
    #42
    12TRDTacoma
    12TRDTacoma Mid Traveling
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    I honestly don't think that would cause the root of his problem. Even if he was using shitty grocery store brand gas they all get their crap from the place. The only difference starts with what additives they throw into their stuff after the fact they obtain their gas (Chevron using their "techron," shell using their "nitrogen enriched" fuel) it's all still from the same guy. I think that would be the last place to look. Especially him living in Tahoe, the computer in every car is leaning the shit out of the gas hence that "fantastic Tahoe gas."
  3. Jan 3, 2013 at 1:06 AM
    #43
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    I'm betting it's a fuel problem, like others have said check your fuel pressure, doubt it's the injectors, it sounds like a problem with fuel delivery
  4. Jan 3, 2013 at 1:30 AM
    #44
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Gotta be a MAF issue I think. Although wouldn't that throw a code??
    D you not have an A/F gauge? That'll instantly tell you if it's fuel problems. You should have one btw for running a 7th injector kit ad e URD pulley. Would be monitored closely.
    Don't just wpswap in injectors. Take all6 to an auto store like car quest and have them test them they should be able to tell you if you have a faulty one.
    But it doesn't sound really like a fuel issue..disabling the URD kit would have made that much worse and more apprent.
    Tim could be a possibility if just one of the cams got off..it that would be way odd..worth checking though I guess. 5vz is a non interference engine so if by some weird chance you did jump a tooth(my guess would be intake side :notsure) it wouldn't really throw a code and you wouldn't really be able to tell right away.
    So...
    Fuel pump
    A/F ratio
    MAF sensor
    Timing
    Coil packs(maybe try swapping those around?)
    That's what I'd be checking now..
    Oh..and..ya know..you could be a pal and send me the SC..ill test it for you..make sure it's umm..working...
  5. Jan 3, 2013 at 1:37 AM
    #45
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Reading before the cats could give him something to go off of, maybe.
  6. Jan 3, 2013 at 6:07 AM
    #46
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    You mentioned cost of a regulator, and not wanting to spend a lot of money. A fuel pressure test kit can be bought for much less than a regulator, and that way you can test your entire fuel system to either find a fault, or rule it out without replacing ANY parts. My suggestion would be to get the proper diagnostic tools. With the small scanner you have that connects to your laptop and a fuel pressure gauge, you will most likely be able to find your problem right there.
    VERY good point brought up here. The sensor can be fine, but if there is a problem with what the sensor is reading, then a good sensor still has a bad signal. Scope is really the only way to know for sure unfortunately when it comes to sensor output.
    That is why you should always use a propane torch (unlit) to find vacuum leaks around the intake. It is a much safer option.
    Just my opinion here...
  7. Jan 3, 2013 at 6:59 AM
    #47
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Yes and the characteristic of the sensor can be swayed by temperature too, even though it may behave within spec at room temperature, at 200*, it may not.
    I would bet on a vacuum leak. have you checked your pcv system?
    Does it have a MAP sensor?
    your engine has knock sensors right, thats what makes it pull timing?
  8. Jan 3, 2013 at 8:10 AM
    #48
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I would post this up at yotatech.com
  9. Jan 3, 2013 at 8:28 AM
    #49
    FramerKat
    FramerKat Well-Known Member
    kAt
    Fort Lauderdale, Florida
    2004 PreRunner TRD Limited DC
    Wheeler's five pack leaf springs, Bilstein 5100s (rear), front tint, windshield top tint, Century Camper Shell/Cap/Topper, Wade window visors, Wade bug shield, cassette adaptor (so I can play Slacker Radio via my phone!), Sunday Blues with Dar sticker, Wounded Warrior Project sticker, no NRA sticker 'cause I don't wanna advertise ;-)
    It's funny, I've had a similar "hesitation" in the past with my Taco. It was primarily in wet conditions here in South Florida when it was raining or I was driving through puddles. I found this thread regarding another member who has a similar situation also. http://www.tacomaworld.com/forum/toyota-trucks-suvs/227204-2003-toyota-tacoma-v6-hesitation.html
    Don't know if there's anything there that can help, but it's worth the read...hope you get yours figured out!
    And mine hasn't done it since "rainy season" here in South Florida...which is the Summer, so I'll wait til next time around to try to troubleshoot it again.
  10. Jan 3, 2013 at 9:09 AM
    #50
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    heres my 2 cents old man. find somebody with a good afm to swap, pull the injectors and have them tested, buy a guage to test the fuel pressure( it will come in handy another day) and double check your grounds and elec connectors(90+% of elec problems are the connections)....sure sounds like something the afm would cause though...good luck and i know youll track it down eventually
  11. Jan 3, 2013 at 9:42 AM
    #51
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
    My truck had the same problem about a year ago. It just ended up being that there was some residue on the MAF that required carb clean and a Qtip to get off. I ended up scrubbing good because I figured I was going to replace it anyways.
    If that doesn't work I would also contact Gadget (URD) and see his thoughts. Maybe a problem in the calibrator for the 7th injector?
  12. Jan 3, 2013 at 10:12 AM
    #52
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    Before or after readings wouldn't make a difference.
    Everyone else do themselves and him a favor and stop suggesting blindly what parts could be bad until he could supply us readings and measurements of emissions. You are only encouraging him to continue his "shotgun" journey of the vehicle. What we are trying to do is make his diagnosis of the vehicle quick and direct as possible. Sending him in 5 different directions is only going to continue to cause him to waste his time. Better off testing it correctly then taking the next step from there. Just my suggestion, and no I'm not trying to be a jerk, sorry If I am coming off as one though.
  13. Jan 3, 2013 at 10:12 AM
    #53
    disc0monkey
    Most definitely can be but a dirty maf is the same effect as a vacuum leak. It's unmetered air entering the cylinders.
    He said he cleaned it already
  14. Jan 3, 2013 at 10:20 AM
    #54
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Maybe you should explain this for me... explain why cats don't affect exhaust readings?
  15. Jan 3, 2013 at 10:24 AM
    #55
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 15 Mustang GTPP
    Too few to list. 10 4runner SR5 4x4- 09 Pre-Runner TRD-OR AC- 14 Prius Two- 08 xB 03 Tacoma 5spd TRD OR 4x4
  16. Jan 3, 2013 at 10:26 AM
    #56
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    Because regardless of the fact that it might be changing exhaust readings it only does it correctly when the vehicle is running at correct AFR. In this case he either dumping gas or running too lean one or the other so readings will be askewed period. To check before cat readings would only be further wasting time. If he is running lean the cats nox reduction bed is deemed useless at the moment because the engine is pumping too much oxygen through and if he is running rich the cat is deemed useless as well because it can only control so much fuel coming through. Either situation (lean or rich) will quickly rear its head out just by shoving the sniffer probe up the tailpipe, given his current running condition.
    Many techs who recommend cats to pass smog without the cats being legitimately bad are only putting a band aid upon the problem because several months down the road or sooner, the issue will rear its ugly head again. To ensure correct exhaust readings you must first correct the running AFR of the engine. Only then will the cats begin to work correctly, if they haven't been jacked up too bad that is.
    We need to get to the root of his issues as quickly and efficiently as possible and taking extra unnecessary steps only will further slow down this process.
  17. Jan 3, 2013 at 10:33 AM
    #57
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
  18. Jan 3, 2013 at 10:38 AM
    #58
    dirty dangler
    adam
    simi valley,ca
    the engine is already torn apart so why not check the easy stuff while your in there. I agree with what you're getting at if the engine hadn't been previously taken apart.
  19. Jan 3, 2013 at 10:43 AM
    #59
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    The AFM can be pulled off at any given moment. As far as injectors and all that is concerned, I agree about that, however, I wouldn't just replace them though and getting them tested is something expensive is it not? I could be wrong, but my point is not to spend money and extra energy on what is not broken until he finds what is broken. Even if the stuff is easy to reach right now, unless he has money to burn, I wouldn't do it. I am just trying to save him extra money and heartache is all.
  20. Jan 3, 2013 at 10:48 AM
    #60
    Blackdawg
    Monte
    Wyoming/St. Louis
    This.
    He has it tore apart. Test the stuff he can while it's apart.
    Jason isn't an idiot either. He knows his way around the truck probably better then anyone in here posting from all the shit he has done. He was looking for people with a similar situation more so the a diagnostics guide I'd guess seeing as how he probably knows how to do that.
    Now it's time to :popcorn: and see what he has to report back.
