Surprise found in diff
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sand_In_My_Taco, Jan 31, 2021.
  1. Jan 31, 2021 at 3:20 PM
    hockeynut258
    hockeynut258 Well-Known Member
    2019 OR MT
    Doesn’t build confidence, time to change my fluids!
    tacotoe and Steves104x4 like this.
  2. Jan 31, 2021 at 3:20 PM
    Sand_In_My_Taco
    Sand_In_My_Taco [OP] Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Update.
    There is much more debris some of it is two or three times the size stuck in the bottom of the differential housing. Attempting to extract now. Pray for me Brothers
    Rockefelluh and Steves104x4 like this.
  3. Jan 31, 2021 at 3:21 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's why they use a magnetic drain plug. To catch that kind of stuff.
    Pouring some juice in the fill plug while the bottom is open may wash out some more. Use the right wt, just cheap stuff, as there will be little residual fluid left with this 'wash' method.
    The reason they don't bother with a magnetic plug in the engine pan is because if you have visual metallic particles it's already too late.
    suaveflooder, tonered and Grossomotto like this.
  4. Jan 31, 2021 at 3:23 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If I found that when I change my fluids, I would be freaked out. I admit anybody who drains their diffs every 30K is a bit OCD.
  5. Jan 31, 2021 at 3:24 PM
    rnish
    Tacoma 2nd gen
    You are still under warranty. May be worth making an appointment with a dealer.
    Big tall dave likes this.
  6. Jan 31, 2021 at 3:28 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    This seems to be the norm for first fluid changes in 3rd gens I’ve done at work
  7. Jan 31, 2021 at 3:28 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    there are mechanic magnets that can be bent to shape to grab things around corners and the like. At this point it might be worth asking the dealer about this, they may want to pull the 3rd member and flush everything out and inspect. That's what I would want if that much came out and there was more, larger stuff still inside. Who knows where some of that stuff may be stuck if that much was left in there from manufacture.
  8. Jan 31, 2021 at 3:29 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    small pieces in BIG diff would not make me panic
    they are where they are supposed to be ............................in the bottom
    not circulating
    dont know why anyone would be doing ANY Drilling .................??
    the fluid does not look that bad
    check again next time
    suaveflooder likes this.
  9. Jan 31, 2021 at 3:31 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    How would Toyota (or the supplier) make all the necessary holes, bearing pockets, etc without machning/drilling/tapping/etc?
  10. Jan 31, 2021 at 3:36 PM
    ROAD DOG
    FEW
    on assembly there is NO drilling
    unless someone really doesnt know what they are doing
    parts should be in order.............clear & clean
    if U were to take it apart..................put it back together
    would U do some drilling......................................short answer NO !!!
    the diff itself requires NO drilling
    in fact what is currently seen I suspect the detritus is from a bearing
    if he is really concerned pulling down the rear end is NOT that difficult or big deal
  11. Jan 31, 2021 at 3:36 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I changed the rear diff lube at 10k miles on my 3rd gen and nothing there but minimal fines on the drain plug.
    2nd gen the same.
    Plan on doing the front diffs in the spring. The 3rd gen has less 300 miles of use on the front.
    My 2016 JKU had one small shaving on the drain plug, looked like the last portion of a thread when it was tapped for the plug.
    Hopefully the OP doesn't find a bunch more with magnet.
    six5crèéd likes this.
  12. Jan 31, 2021 at 3:39 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    I wonder...are the carrier attachment holes blind? With a stud installed?
  13. Jan 31, 2021 at 3:41 PM
    Sand_In_My_Taco
    NOR*CAL
    Bunch more shavings came out, I'm just going to save it all.
    Filling it up now, will check again on next oil swap.
    Should have everything filtered through at that point.
    Kev250R and tacotoe like this.
  14. Jan 31, 2021 at 3:45 PM
    ROAD DOG
    FEW
    id pull the driveshaft.............
    pull the pumpkin
    check the outer wheel axle bearings
    its not difficult everything unbolts
  15. Jan 31, 2021 at 3:57 PM
    #35
    GrundleJuice
    Michigan
    2016 TRD Bro
    No shit. There are many processes that take place to make a rear axle before assembly. They don't just spontaneously materialize into existence.
    Are you making the argument that someone missed something significant during manufacture/assembly or that you think that material is from a wearing bearing?
    It's under warranty. Pulling it apart would just screw him over for any warranty consideration.
    DeeKay20, trktwo and tacotoe like this.
  16. Jan 31, 2021 at 4:02 PM
    #36
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    This thread is gold, Jerry, gold!
    MadKatt, trktwo, Thatbassguy and 2 others like this.
  17. Jan 31, 2021 at 4:04 PM
    #37
    ROAD DOG
    FEW
    welding on shock mounts
    studs........drilling for bolt is NOT done at assembly
    parts are prepped & checked then moved to assembly
  18. Jan 31, 2021 at 4:05 PM
    #38
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That's why the plug is magnetic
    You mean like treading holes? Carrier bolts, ring gear bolts, drain/fill plugs, bearing bores and so on?
  19. Jan 31, 2021 at 4:07 PM
    #39
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The vent fitting is drilled and tapped post casting, as are the bolt holes for the 3rd member. Lots of drilling and tapping on a Toyota differential housing. Some of this detritus got missed in the cleaning process.
  20. Jan 31, 2021 at 4:08 PM
    #40
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Somebody’s missing a 10mm socket. You just found it.
    rnish, Delta09, trktwo and 5 others like this.
