Surprise when checking cabin air filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brentm, May 4, 2009.
  1. May 4, 2009 at 2:15 PM
    brentm
    brentm [OP] Member
    Got in the truck today and noticed a smell of dry/dead grass. Got home and checked the cabin air filter and found this:eek:
    The filter was chewed slightly, and I think something was building a nest for the last day or two. I smelled the filter and it smelled like grass, no smells of urine and no signs of feces.
    I checked the engine air filter and it was clean, and I can't see any visible signs of chewed wires nor where the critter is getting into the vehicle.
    The truck is always parked with windows rolled up and hood closed.
  2. May 4, 2009 at 2:18 PM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
  3. May 4, 2009 at 2:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!!!
    Holey SHIZNIT!!!!
  4. May 4, 2009 at 2:19 PM
    brentm
    brentm [OP] Member
    Has anyone had this problem before. I looked but cant see where the air intake is for the cabin filter. Is it behind the passenger side fender linings? Or does it brand off of the main engine intake?
  5. May 4, 2009 at 2:19 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    did someone play a trick on u?
  6. May 4, 2009 at 2:23 PM
    brentm
    brentm [OP] Member
    Haha no, I was half expecting a squirrel baby or something to jump out when I was cleaning it out though.
  7. May 4, 2009 at 2:23 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    i've found stray pieces of pine straw or leaves, but nothing of that extent
  8. May 4, 2009 at 2:30 PM
    brentm
    brentm [OP] Member
    OakleyTRD: Thanks:D
    So heres the battle plan. I got it all cleaned out with my car detailing vacuum and after I cleaned it out I put the hose on the blower end and blasted out the vents, didn't see anything other than a few strands of grass.
    Tha majority of the grass was above the filter in the top of the cabin filter box. Vacuum made quick work of that.
    Does anyone have a location of the air vent intake. I'm going to put some metal mesh over the hole. The stuff you see on the bumpers of civics haha.
  9. May 4, 2009 at 2:45 PM
    brentm
    brentm [OP] Member
    From another thread search. Thanks chris4x4 haha
  10. May 4, 2009 at 3:03 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    Not in a Taco, but my sister had rats nesting in her new Suburban and they wrecked the wiring. Was a LOT of money to fix.
  11. May 4, 2009 at 4:45 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I found rat droppings in mine im just happy the little rat didnt eat wires!
  12. May 7, 2009 at 6:13 PM
    brentm
    brentm [OP] Member
    UPDATE: SOLVED.
    Took my day off and troubleshot the rodent problem.
    Been checking the filter daily to see if any more signs of the rodent were present. None were found.
    I popped the windshield cowl off and saw exactly where the system brings outside air in. If you pop the cowl off and look on the passenger side, it is immediatly obvious.
    Went to home depot and got some 1/2" by 1/2" metal screening and screwed that into place...There was 2 existing screw holes from factory...maybe they knew this would be an issue?
  13. May 7, 2009 at 6:33 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    or maybe they didn't put a screen on when the truck was built!! Remember they are built in north america or mexico now...not in Japan. Could be a quality control thing!!!
  14. May 7, 2009 at 7:26 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Damn that was a ton of shit. Did you air even blow with that in there? Glad you got it solved.
