Surprising Lift Measurements
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gudujarlson, Sep 11, 2021.
  1. Sep 11, 2021 at 7:53 AM
    gudujarlson
    gudujarlson [OP] Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It's been about 1.5 years since I installed my King extended length shocks and medium dakar leaf springs. I left the preload as it came. At the time I measured the ride height and droop before and after the lift, but I didn't write any of it down. Doh! I remember my front hub to fender distance being about 21" stock and 23" lifted and having about 3" of droop stock. I don't remember the other measurements.
    Today I measured again and I was a bit surprised by the results.
    Sitting level on the ground with 30lb skid, 150lb sliders, and 30lb in the bed.
    FL 21.5"
    FR 22.5"
    RL 23"
    RR 23.5"
    Jacked off the ground by the frame:
    FL 25.5" (4" droop)
    All of these are +/- .25" because I find it unreliable to find the center of the hub and also keep the tape measure perfectly vertical.
    I also measured my ground clearance at two points. I have 255/85R16 tires at 37 psi and the larger diff.
    rear diff: 10.25"
    front skid oil drain door: 12.5"
    Conclusion:
    It looks like I'm basically back to stock height in the front and have plenty of droop to play with. I might be doing some preload adjustment soon.
    Can someone please post their stock measurements so I can refresh my memory?
    CherylJane and FishnTx like this.
  2. Sep 11, 2021 at 7:58 AM
    tcjacado
    tcjacado Well-Known Member
    If I remember rightly, its 21 driver front, 21.5 passenger front and 22.5 passenger rear and 22 on driver rear.
  3. Sep 11, 2021 at 8:54 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What are the measurement points taken from? Top of fender arc?
  4. Sep 11, 2021 at 9:07 AM
    gudujarlson
    Minnesota
    I measured from center of the hub to the edge of the fender flare directly vertical. When comparing to other trucks, this makes the assumption that all fenders flares are the same, which is something I've never verified personally. I have the stock OR fender flares.
  5. Sep 11, 2021 at 9:33 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yikes. I have these numbers on 5100 w/885 coils.
    CherylJane likes this.
  6. Sep 11, 2021 at 9:37 AM
    gudujarlson
    Minnesota
    Isn't a 885 a 2nd gen coil? It's short at 395mm, yes?
  7. Sep 11, 2021 at 3:35 PM
    Vlady
    Issy, WA
    Not sure about 2 gen, but I gained 1.8" of lift and center of hub to the fender numbers are holding up at 22.5 (+-)
    CherylJane and 71tattooguy like this.
  8. Sep 11, 2021 at 3:57 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    2/1" Bistein 5100 Lift, (stock front coils).
    37" all around, from under black fender wells (Off Road Taco).
    1/2">1" rear diff. ground clearance (265/75/16 Duratracs).
    71tattooguy likes this.
  9. Sep 15, 2021 at 10:10 AM
    gudujarlson
    Minnesota
    I measured again today and got slightly different results. I now think my error is +/- 0.5". Maybe I need to practice my tape measure skills? Part of the challenge is that the lighting in my garage is lacking, the fender flare is black, and I have old eyes.
    Hub to center sitting on level ground:
    FL 22"
    FR 22.5"
    RL 23.5"
    RR 24"
    I also measured ground to fender:
    FL 37.25"
    FR 38"
    RL 39"
    RR 39.5"
    These look closer to what I expected. I have a ~1" lift in front and a ~1.5" lift in the rear. I still have some room to spare. I wouldn't mind adjusting my preload on the front, but I'm thinking that adding an extra leaf or block to the rear is not worth it; at least not until if and when I add significant weight to the rear. I do have tentative plans to add aluminum front and rear bumpers and a winch, no toppers, racks, tents, or anything of that sort.
  10. Oct 16, 2024 at 6:51 PM
    Mdtageant
    Mdtageant New Member
    Marlon
    2017 Tacoma Sport
    Level kit and added Bilsteins shocks
    My 2017 Tacoma sport sits 38" off ground front and back, with 275 r17.
    What lift do I have?
  11. Oct 16, 2024 at 6:53 PM
    gudujarlson
    Minnesota
    You need to look under your truck at your suspension parts and look for labels. That or takes pics and upload them.
  12. Oct 18, 2024 at 5:22 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    The trusty tape measure never lies. But I too find that 1/2" difference or operator error.
    Perhaps the only accurate measurement time to take them is after it's been sitting in the garage overnight. Kind of like taking tire air pressures. It's like a moving target the rest of the day.
  13. Oct 18, 2024 at 6:42 AM
    gudujarlson
    Minnesota
    It’s measurement error. It’s difficult to hold the tape measure in the same place each time. Also, if it’s dark like in my garage. It’s hard to see where the (black in my case) fender intersects the tape measure.
