Suspension Advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EVErsionDesigns, Jul 18, 2011.
  1. Jul 18, 2011 at 7:30 PM
    EVErsionDesigns
    EVErsionDesigns [OP] Well-Known Member
    Trent
    92399
    '11 4wd TRD OffRoad
    Grillcraft, White Surround, 2x20" LED Bars, Wet Okole, Bed Lights, TRD Intake, TRD Exhaust, TRD TT Wheels, OMF Beadlocks, BFG KM2, Camburg UCA, 2.5" ICON RR front coils w/ comp. adj., 2.5" ICON RR rears w/ comp. adj., 2.0" ICON air bump system.
    I want to know if anyone with an aftermarket UCA is having trouble with alignment, broken tie rod ends, balding tires or anything of that nature.
    I want to get some and I want to make sure I'm not running into something too expensive with replacing tires and everything.
    Is there any that won't void the warranty?
    Thanks for your help.
  2. Jul 18, 2011 at 7:35 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Well, I just put on some LR UCA's, and the alignment shop fucked up. Gotta take it back in the morning. The right tire scrubs like fuck now when I turn right. :(
  3. Jul 18, 2011 at 7:37 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    They set at their neutral setting ?
  4. Jul 18, 2011 at 7:37 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Warranty only gets void if the product directly causes the problem.
    If anything aftermarket UCA's will help with all the above mentioned items because they WILL allow for proper alignment allow tires to wear evenly and such.
    They dont have anything to do with tie rods because toe can always be adjusted even without proper camber and caster.
    Please someone correct me if I am wrong, thanks!
  5. Jul 18, 2011 at 7:41 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    lol not even close. The freaking square bushing thing that sets in the groove (above the ball joint), he has it turned sideways. . . not even seated in it's place. :(
  6. Jul 18, 2011 at 7:42 PM
    OZ-T
    Peter North
    British Columbia
    You have the install instructions ?
  7. Jul 18, 2011 at 7:43 PM
    EVErsionDesigns
    Trent
    92399
    '11 4wd TRD OffRoad
    I'm just concerned with the tie rod ENDS being more vulnerable with the aftermarket suspension.
    I had a 4" spindle lift on my old truck and I could break tie rod ends all day.
  8. Jul 18, 2011 at 7:47 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Ya. I forgot them today, and I was hoping they knew what they were doing. Guess not. I'm taking the instructions up there in the morning. The left side is fine... Idk what he was doing o the right. . .
  9. Jul 18, 2011 at 7:48 PM
    08pretaco
    Oliver
    az
    How would a UCA cause a tie rod end yo break?
    How on earth were you going through ends?
  10. Jul 18, 2011 at 8:38 PM
    EVErsionDesigns
    Trent
    92399
    '11 4wd TRD OffRoad
    Thats what I'm asking.
    More if anyone has had any problems though..
    Like MXracer190, I want to know that kinda stuff but it sounds more like something wasn't put together right, rather than a natural mechanical issue.?
    It was a heavy truck with a weak front end and heavy tires. A sierra 1500 with 37" tires. The front end had seen better days. It always had problems with the alignment too, never had it straight.
  11. Jul 18, 2011 at 8:45 PM
    08pretaco
    Oliver
    az
    Ah now I see. I was like i have not heard of people changing out their rod ends that often on a Tacoma
  12. Jul 19, 2011 at 8:19 PM
    EVErsionDesigns
    Trent
    92399
    '11 4wd TRD OffRoad
    Well then I guess that answers my question lol
  13. Jul 19, 2011 at 8:27 PM
    08pretaco
    Oliver
    az
    iv been running my spindles for over a year and a half with no issues whatsoever. I also have Total Chaos Upper arms and it allows for me to run the extended travel shocks to achieve a bit over 9 3/4" of travel over the factory 8.
  14. Jul 20, 2011 at 5:44 PM
    EVErsionDesigns
    Trent
    92399
    '11 4wd TRD OffRoad
    ya I like the set ups.
    Im looking at the Icon UCA.
  15. Jul 27, 2011 at 11:59 AM
    EVErsionDesigns
    Trent
    92399
    '11 4wd TRD OffRoad
    Awesome. Thanks.
