Suspension Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iLoveTacossssss69, Aug 9, 2019.
  1. Aug 9, 2019 at 7:10 AM
    iLoveTacossssss69
    iLoveTacossssss69 [OP] Well-Known Member
    Arizona
    2018 TRD Sport
    I was looking at the head strong coil/bilstein kit for my 2018 Trd Sport 4x4. I don’t know what coil I need or if I need the Deaver single AAL or the HS 3 leaf AAL. I want to have a 2-3 inch lift and have my truck sit level. I will also be having a SOS Concepts hybrid bumper that I think weighs around 80lbs with NO winch. If I do order this kit will I also need to get a diff drop? Will I need extended break lines or anything like that?
  2. Aug 9, 2019 at 7:18 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Contact Headstrong, they will help you with all your question/needs.
    iLoveTacossssss69[OP] likes this.
  3. Aug 9, 2019 at 7:19 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You should change the title of the post to some thing like "Suspension Advice Please". "Help" is a reserved word.
  4. Aug 9, 2019 at 7:19 AM
    tcjacado
    tcjacado Well-Known Member
    You need advice, not help. Please remove help from the title. Go to thread tools at the top of post 1 and edit title.
    @HeadStrong Off-Road
  5. Aug 9, 2019 at 7:20 AM
    iLoveTacossssss69
    Arizona
    2018 TRD Sport
    Can I get some answers now ?! Lol
  6. Aug 9, 2019 at 7:23 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Headstrong all the way. One stop shop.
  7. Aug 9, 2019 at 7:23 AM
    tcjacado
    You are looking at an entire lift kit, coil overs with 700lb springs, new leaf pack (hd if carrying any weight in the rear). Shouldn't need extended brake lines and the diff drop may or may not be needed to keep CV joints in proper angle
  8. Aug 9, 2019 at 7:39 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Why do members use this word on titles? It's like yelling "Fire!"
  9. Aug 9, 2019 at 7:40 AM
    iLoveTacossssss69
    Arizona
    2018 TRD Sport
    It got ur attention which is what I wanted !!
  10. Aug 9, 2019 at 7:41 AM
    rnish
    Tacoma 2nd gen
    If you keep the lift to 2” your CV angle(s) should be ok and shouldnt need extended brake lines up front.
    Only adding a 80 pound bumper? If you’re adding a set of skids and sliders they will add ~300 pounds quick. Then consider a 650-700 lb springs on the coilovers.
  11. Aug 9, 2019 at 7:51 AM
    tcjacado
    And it was the wrong way to go about it. Talk to Marie and buy your kit.
