suspension and coil overs
Discussion in 'Suspension' started by takaya49, Nov 3, 2010.
  1. Nov 3, 2010 at 4:04 PM
    takaya49
    takaya49 [OP] Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    hi Tacomaworld!
    so im adding suspension. about a 3 inch because i still need to fit under my door.
    question is do i really need larger springs and or coil overs?
    I ride about 1000 miles a year of dirt road and like to drive fast.
    I used to have donahoe in the past.
    my mechanic said dont waste your money on bigger springs if its just a 3 inch lift...
    any idead? im thinking ICON because they used to be donahoe but also revtek with extra shox with resevoirs? are resevoirs really worth it if im not doin baja?
  2. Nov 3, 2010 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Icon, King and Fox would be good CO's to consider.
  3. Nov 3, 2010 at 4:25 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Yeah pretty much.
  4. Nov 3, 2010 at 4:32 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    But are bigger coils really neccesary it with a 3 inch lift?
    mechanic is sayin just a simple revtek lift with 5100's...
  5. Nov 3, 2010 at 4:46 PM
    jandrews
    '09 FourDubDee TRD OR
    Define "necessary". What do you want the truck to DO?
    I did a 3" with remote resi Icons all around because I wanted this truck to stand up to any pounding I would put it through without blinking.
    If it's going to be babied, you'd be fine with something like OME or Toytec. If you're broke and don't care about a shitty ride, there's always spacers.
    The BEST way to do a 3" lift on these trucks is COs...but not everyone needs best.
  6. Nov 3, 2010 at 4:59 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    i dont do a lot of heavy 4 wheelin/4 low gear stuff... mostly just shitty dirt roads, pot holes while fast driving...about 1000 clicks a year
  7. Nov 3, 2010 at 5:19 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    I like your susp set up jandrews.. what did it cost? and how are your km2 in the rain?
    I had them on my old taco and was slick but attributed it too the light back end...
    anyone have ideas the best place to shop in the bellingham area? does this stuff ever go on sale?
  8. Nov 3, 2010 at 5:26 PM
    jandrews
    Expensive. COs, Shocks, AAL, and UCAs were about 2400 altogether. I did the install myself. Expect to shell out for 2 or 3 alignments over the next couple months after you install to get your specs dialed in.
    I couldn't tell you about rain because I've had the setup on for 4 days and it hasn't rained yet. TRAC has been excellent in rain and snow in the past however, keeping the ass-end very much in check.
  9. Nov 3, 2010 at 5:31 PM
    ktmrider
    Junk
    I pushed it a little too far with the km2s a couple weeks ago. I was taking a left hand turn at like 11 at night onto the expressway and ended up backwards in the dirt. Just drive it a little easier then you would a normal street tire.
  10. Nov 3, 2010 at 5:36 PM
    takaya49
    Brent
    Vancouver BC
    tacos
  11. Nov 3, 2010 at 5:58 PM
    ktmrider
    Junk
  12. Nov 3, 2010 at 6:01 PM
    jandrews
    That is an excellent kit, but I would note:
    Icon UCAs are much more expensive for almost no performance difference compared with TC, Built Right, etc.
    I would try to find an Icon kit without the UCAs and AAL and buy those separate...and save the dough.
    Alternatively, if you want to spend the same amount, buy TC UCAs and get leaf packs instead of AALs.
  13. Nov 3, 2010 at 6:17 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    so what exactly should i get from ICON?
  14. Nov 3, 2010 at 6:25 PM
    ktmrider
    Junk
    You dont have to get it from icon, but to get a good 3 inch lift with proper alignment you need: Coilovers, UCAs, new rear shocks, An AAL or a new leaf pack
  15. Nov 3, 2010 at 6:28 PM
    jandrews
    Slow down. Take your time. Research this. We're talking about serious change here.
    Icon makes awesome products all around. EVERYTHING they make is good. However, you can get some things for a lot less than are 99.9% as good or better in some ways.
    Example: Icon billet control arms are about a grand. Total chaos control arms are $650ish. The difference in performance is almost nil. There is no justification for the extra cost of the Icons, other than the fact that they're manufactured in a much more expensive way.
    Icon makes great suspension products. King makes great suspension products. Fox makes great suspension products.
    Search the forums. Get input from people running each. Learn about some of the problems with lifting (carrier bearing and driveshaft vibes, harsh CV angles, alignment issues, etc.)
    This is not something you want to jump into unprepared.
  16. Nov 3, 2010 at 6:31 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Icon, king, or fox front and rear with tc uca's and new leafs in the back.
  17. Nov 3, 2010 at 6:31 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Hey! I heard that:mad::p
  18. Nov 3, 2010 at 6:39 PM
    jandrews
    :p
    OME is fine if you're pushing it, but I know a couple guys on here have blown OME shocks wheeling hard. It's A quality stuff for the price though.
  19. Nov 3, 2010 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....Im gonna disagree with OME being any less stout than the others. Anyone can blow a shock. OME is every bit as tough as the other stuff.
  20. Nov 3, 2010 at 8:37 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    OME Nitro charged vs ICON shocks with res?
