Suspension and wheels size suggestions
Discussion in 'Suspension' started by Rodriguez801114, Jul 31, 2024.
  1. Jul 31, 2024 at 1:17 PM
    Rodriguez801114
    Rodriguez801114 [OP] Member
    Hey yall, i recently bought a 2022 tacoma SR5 and im looking to get new shocks and wheels but im not sure what to get. I mostly want shocks for regular everyday road use but also to hit the trail on some occasions. Any suggestions id appreciate it.
  2. Jul 31, 2024 at 1:18 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Honest answer for that application is to keep your OEM shocks and bump to a +1 tire size (265/75-16) and enjoy. Best bet.
  3. Jul 31, 2024 at 1:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Why do you think you need new anything? It's only a couple years old.
    Maybe better tire, depending on what's on there ?
  4. Jul 31, 2024 at 1:41 PM
    Rodriguez801114
    to be honest i like the look of a lifted Tacoma and want mine lifted as well
  5. Jul 31, 2024 at 1:52 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
  6. Jul 31, 2024 at 1:55 PM
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    Whatever you do, dont spacer lift just to fit a bigger tire. A better quality tire, airing down (assuming clearance isnt the issue youre trying to overcome) and driver knowledge is 100x more important than sidewall size.
    Clearwater Bill likes this.
  7. Jul 31, 2024 at 2:01 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Unrelated. Earlier I saw what looked like I'd say a 1970 Ford pickup regular cab long bed with maybe a 1 foot lift and rolling on something bigger than 40s, it was bad ass!
    For a Tacoma Bilstein,Fox, Eibach with or with out coils already on them. Or anything similar.
  8. Jul 31, 2024 at 2:04 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Ok. Wheels and shocks don't necessarily lift your truck. A better question would be how much do you want to lift your truck, what's your budget and are you just occasionally driving on fire-roads or will you be doing more serious off-roading and crawling. Honesty matters since more functionality typically requires more $$$.
    Lifting the truck over 2.5" typically requires spending more money for adjustable upper control arms (UCAs).
    You can search the 3rd gen forum for the following terms and learn a bunch:
    2" lift
    what size tire fits without trimming
    leveling kit
    spacer lift
    factory trd lift kit
    ..and fwiw larger tires and tires that are made for heavy off-roading are typically heavier. Heavier means the truck will be slower. For all I know you do not care about acceleration.. but if you do tire size and weight will be a factor.
  9. Jul 31, 2024 at 3:37 PM
    Rodriguez801114
    Honestly i was thinking a 2-2.5 lift, i don't have any plans on doing any serious off-roading or crawling, i have a budget of $1000-$1700
  10. Jul 31, 2024 at 8:34 PM
    Gen3TacomaOBX
    S
    Is that budget for the lift/suspension changes alone or does that include tires?
