suspension blocks and towing
Discussion in 'Towing' started by Cnasianfire, Mar 9, 2018.
  1. Mar 9, 2018 at 3:27 PM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Just figured out that I have suspension blocks on the rear axle. Will that reduce the amount that I can tow safely?
  2. Mar 9, 2018 at 6:22 PM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    How thick are they?
  3. Mar 9, 2018 at 6:28 PM
    awdvkd115
    Bud
    2017 Tacoma TRD OR
    Blocks cause axel wrap and can cause spring breakage. Towing does aggravate the situation when you tow. The extra weight when you take off or accelerate will cause the spring to flex worse cause fatigue or breakage. You could remove them and replace the rear springs or do add a leaf. Good luck!
  4. Mar 9, 2018 at 6:43 PM
    Cnasianfire
    Charles
    Wilmington, NC
    2 inches
  5. Mar 9, 2018 at 6:46 PM
    Cnasianfire
    Charles
    Wilmington, NC
    Yeah, i plan on doing that at some point, need to recover from the KO2s that I just bought. I don't think that I have much if any noticeable axle wrap.
