suspension change
Discussion in 'Suspension' started by wkbrd449, Aug 20, 2009.
  1. Aug 20, 2009 at 3:00 PM
    wkbrd449
    wkbrd449 [OP] New Member
    tucson
    09 off road longbed
    nerf bars 2' lift skid plate
    I bought my tacoma with a 2in lift but the front was lower then the back probably because of the aal. I took it to the shop and they were able to lift the front 2in with the existing lift kit which is an icon kit. Now my truck is more level and looks better but i noticed it takes speed bumps/humps more roughly. Do anyone know why this could be? Is it bad?
  2. Aug 20, 2009 at 3:08 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    from my experience coilovers are not meant to be a lifting factor,dont raise it more than expected height and thats where you get the rougher ride in time you will cause stress to the internals, in my case thats what happened to mine my coilovers they were shot because they were lifted beyond their max, and i took the previous owners word that they were still good and did not need a rebuild, but how long have the icons been on?
  3. Aug 20, 2009 at 4:25 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The higher you crank your coilovers (I'm assuming that's what you have) the rougher the ride will be.
  4. Aug 21, 2009 at 12:04 AM
    wkbrd449
    tucson
    09 off road longbed
    the truck is just about a year the mechanic said as long as part of the axil that the wheels are attached to isn't at to steep of an angle the its ok, theyre at about a15 or 20 degree, should i get it lowered
