Suspension Failure
Discussion in 'Suspension' started by Spillbert, Jul 22, 2021.
  1. Jul 22, 2021 at 11:25 AM
    Spillbert
    Spillbert [OP] Active Member
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    Howdy Folks,
    My 2014 T-Force is my second Tacoma and loaded with extras, which is why I purchased it. Just turned 82,00 mi. and the left rear Bilstein Shock seal has blown out and leaked al the fluid out of it. Also the rear drive shaft has started shaking and making lots of noise at any speed over 60 mph. Very little off road driving and only pulled a trailer with my motorcycle on it two times. I thought these were pretty much bullet proof trucks. Anyone else have similar issues?
  2. Jul 22, 2021 at 11:27 AM
    Tacocement5
    Tacocement5 Well-Known Member
    Northwest Indiana
    2021 Toyota Tacoma TRD Off Road
    Stock and orignal bilsteins or aftermarket?
    the.sight.picture likes this.
  3. Jul 22, 2021 at 11:28 AM
    Tacocement5
    Northwest Indiana
    "Loaded with extras" is the truck lifted?
    ToyoTaco25 and SR-71A like this.
  4. Jul 22, 2021 at 11:29 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Well depends on maintenance. Sounds like this one wasn't maintained properly or just time for some parts to need maintenance.
  5. Jul 22, 2021 at 11:31 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    its a 2014 with 82k miles on it. Shocks are wear items, replacement would be pretty standard after that amount of time and miles. Its used, so you dont know what the other person did with the truck. And whats a T-Force?
    ToyoTaco25 and PasoSteve like this.
  6. Jul 22, 2021 at 11:32 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Original Bilsteins should give you around 50K miles, plus or minus 20K. Some people keep them longer, but even if they haven't blown a seal they are no longer doing their job effectively. Time to replace.
    Check your center support bearing. Rubber has probably degraded, time to replace.
    SR-71A likes this.
  7. Jul 22, 2021 at 11:32 AM
    Tacocement5
    Northwest Indiana
    For all you know the previous owner could have beat the shit out of the truck.
    stevesnj likes this.
  8. Jul 22, 2021 at 11:34 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    It's like the TX package. Different wheels and tires, headache rack with some KC style lights, and 5100's. Stuff like that
  9. Jul 22, 2021 at 11:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Some kind of dealer mark up fluff?
    @Spillbert not sure how you know the D/S is shaking, but a failed u joint or center bearing would be where to start looking.
    @ 82k, OE shocks are done anyway, assuming that's what you have.
    Are you the original owner?
  10. Jul 22, 2021 at 11:36 AM
    Spillbert
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    It is not lifted and has no after market modifications. All the required Toyota maintenance has been done along with oil, filter and air filter every 3000 miles. Being an A/P aircraft mechanic, I am extremely big on continuing maintenance. These are the original OEM Bilstein shocks that came on it. Up till 4 days ago it has worked perfect, even pulled a couple of Jeeps out of the ditch in front of my house during this winters ice storm that hit us! Thanks for the reply!
  11. Jul 22, 2021 at 11:38 AM
    stevesnj
    Well seems like it's just time. A well maintained Toyota typically is figuratively 'bullet proof'. But mechanical parts all have a wear limit.
    Thunder Fist and OmahTako like this.
  12. Jul 22, 2021 at 11:38 AM
    Spillbert
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    I am the original owner. I did figure the u-joints were causing the vibration and noise, which the dealer confirmed, just can't imagine them going out at 82,00 mi. or the shocks for that matter either.
  13. Jul 22, 2021 at 11:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Well that's confusing.
    ToyoTaco25 and tcjacado like this.
  14. Jul 22, 2021 at 11:38 AM
    tcjacado
    tcjacado Well-Known Member
    Check the Pinion bearing, carrier bearing, u joints and replace the rear shock.if irmts leaking.
  15. Jul 22, 2021 at 11:39 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    They wouldn't be aftermarket to him if it came from the dealer that way. A TRD Pro has Rigid fogs and Fox shocks, are those aftermarket?
  16. Jul 22, 2021 at 11:41 AM
    tcjacado
    I'll bet the service department says "yes" to that.
    skeletron[QUOTED] likes this.
  17. Jul 22, 2021 at 11:44 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Normal wear items. Shocks, U-joints and carrier bearings are all “moving” parts and wear out after 7-8 years and 80 000 miles.
    PasoSteve likes this.
  18. Jul 22, 2021 at 11:45 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Fair play
    tcjacado[QUOTED] likes this.
  19. Jul 22, 2021 at 11:45 AM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Sometimes parts just wear out. No rhyme or reason. Ive seen 5 year old belt tensioners fail but my Mazda still had its OE belt tensioner on it 21 years later when I finally changed it. Vehicles are just like that.
  20. Jul 22, 2021 at 11:46 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    5100s in the rear on a stock height truck could be too long
