Suspension Failure
Discussion in 'Suspension' started by Spillbert, Jul 22, 2021.
  1. Jul 22, 2021 at 11:49 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    The OEM bilsteins on my truck didn't even make it to 100k miles on my truck.
    Sounds like the carrier bearing and/or u-joints are going out, but to get to the carrier bearing, you'll need to disconnect/remove the driveshaft. If you're replacing 1 u-joint, might as well replace all 3. My carrier bearing and u-joints lasted me nearly 300k. I've been lifted for 270k and driven hard the entire time so it's a bit weird that your carrier bearing and u-joints haven't lasted all that long. It could be environment with water, dirt, sand, contaminants getting into the u-joints. Also, I doubt that the dealership adds grease to the u-joints. I add grease every time I change my oil versus Toyota maintenance recommends, what, every 30k?
  2. Jul 22, 2021 at 11:49 AM
    Spillbert
    Spillbert [OP] Active Member
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    Center support bearing, had not thought of that, good idea, THANKS!!!
  3. Jul 22, 2021 at 11:50 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    The rears might actually be 5160s
  4. Jul 22, 2021 at 11:52 AM
    Bishop84
    Bishop84 Well-Known Member
    Shocks wear out? Toyota doesn't make them, they outsource shocks and install them. Is the tacoma falling apart? Did you make this account to complain?
  5. Jul 22, 2021 at 11:53 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Damm 82k on a 2020!
  6. Jul 22, 2021 at 11:55 AM
    Spillbert
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    My understanding of the bearings for the drive shaft is that they are sealed bearings and cannot be greased, I will check that out when I get it back. The drive shaft will include all the bearings and u-joints for it. THANKS
  7. Jul 22, 2021 at 11:57 AM
    Spillbert
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    Not a 2020, it's a 2014 and I am not here to complain, just here to learn, and have read some good advice so far!
    skeletron likes this.
  8. Jul 22, 2021 at 12:01 PM
    Spillbert
    Phil
    Fort Worth Texas
    2014 Tacoma T-Force
    None
    As a side note, I also have a 2001 Suburban 2500 w/8.1 liter, with 230,000 miles on it and just now got the trans. o'hauled which is the first major repair aside brakes, etc. I expected the same or more from my Taco, that is why I'm dismayed over the recent failures.
  9. Jul 22, 2021 at 12:02 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    sorry not sure where I saw 2020.
    tcjacado likes this.
  10. Jul 22, 2021 at 12:03 PM
    Tacocement5
    Tacocement5 Well-Known Member
    Northwest Indiana
    2021 Toyota Tacoma TRD Off Road
    comparing a transmission over haul to a shock/bearing failure is apples and oranges lol
    tcjacado and Toyko Joe like this.
  11. Jul 22, 2021 at 12:56 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    If you're 2WD, then they are sealed. If you are 4WD the u-joints have grease zerks (5). 3 on the rear and 2 on the front drive shaft.
  12. Jul 22, 2021 at 1:13 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    On my 2012 2nd gen, I swapped over to 5100's at about 50K miles. The carrier bearing started wobbling causing a vibration in the driveshaft at about 90K miles. U-joints were fine, though.
  13. Jul 22, 2021 at 2:03 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Hmm, an 8 year old truck with 82,000 miles and you have 1 bad rear shock (not made by Toyota) and driveshaft vibe issue that is well known and documented with relatively easy fix. Curious why you’re “dismayed” about such a simple issue? Especially being a mechanic…
  14. Jul 22, 2021 at 5:02 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    Toyota discontinued the serviceable U-Joints a while back. You'll need to get them from Spicer if you want the greasable version.
  15. Jul 22, 2021 at 6:50 PM
    #35
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    When? As far as I know every second gen 4x4 had greasable U joints.
  16. Jul 22, 2021 at 7:01 PM
    #36
    CadCamMan
    TRD SC, suspension
    Yes, the trucks come from the factory with them. Replacement parts were superseded long ago and are not serviceable, part number 04371-04031.
    I ordered the Spicer U-Joints and rebuilt the driveline on my truck a few weeks ago. One U-Joint was correct, one was packaged incorrectly (wrong part), and the third one did not fit (distance over bearing caps too long).
    Needed to make a trip to the dealer for two U-Joints and just like I'd heard, no zerk fittings.
  17. Jul 22, 2021 at 7:04 PM
    #37
    Bishop84
    Yup warranty extension for the 2nd gen joints replaced with no zerk.
    Honestly they are better off.
  18. Jul 22, 2021 at 7:10 PM
    #38
    Sharpish
    Brian
    Fair enough but it sounds like his stuff is stock and he never greased them. Probably why they failed no?
    He has a 2014 and I have a 2012 and no warranty enhancement on mine.
  19. Jul 22, 2021 at 7:16 PM
    #39
    CadCamMan
    TRD SC, suspension
    Assuming he has zerk fittings, if they don't get used then yes it would be reasonable to expect the U-Joints to fail fairly early.
