Suspension for towing 19 foot boat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chueflee, Feb 27, 2020.
  1. Feb 27, 2020 at 10:30 AM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    What is a good suspension setup for towing my 19 foot ranger rt198 aluminum boat. Total weight of boat and trailers is around 3000lbs.
    DG92071 likes this.
  2. Feb 27, 2020 at 10:44 AM
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    Aluminum boat, you're all set soon as you get a 2013 taco w/V6. :broccoli: Enjoy
    DG92071 and TacomaWilly like this.
  3. Feb 27, 2020 at 10:53 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Yeah, boats are typically quite tongue light, especially aluminum fishing boats. Now if we were discussing a camper trailer, we'd have some talking to do.
  4. Feb 27, 2020 at 10:57 AM
    Taruuk
    Taruuk Well-Known Member
    2017 Tacoma OR MT AC
    I will be towing a ~3000lbs camping trailer this spring/summer. What is this talking you speak of?
  5. Feb 27, 2020 at 10:59 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    with a boat most of the weight is behind the axle. rv most the weight is in front of the axle. atleast in most cases.
  6. Feb 27, 2020 at 10:59 AM
    chueflee
    Chue
    hehe i know i've been towing it for 2 years. But my shocks are starting to squeak. my truck has 82000 miles now with original suspension. was wondering what shocks should i change to that are close to stock. I wanted to upgrade the leaf springs also
    DG92071 likes this.
  7. Feb 27, 2020 at 11:04 AM
    Taruuk
    I understand that the tongue weight of a camper will be greater in a travel trailer. I haven't checked my tongue weight since i first bought it. At the time it was 200lbs. I would assume it's greater since I've been living in it for the last 7 months. My unit is also 19ft long.
    I intend to take my sway bar off to get a feel for better articulation but know it's required upfront for safe towing. What would improve safety & overall ride in the back?
    Edit: added second paragraph
  8. Feb 27, 2020 at 12:13 PM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    Lots of options but depends on what you're willing to spend. I added a leaf (AAL) and then added RideRite air bags and couldn't be happier. This setup offered me a full range of options from towing to bed load since the pressure can be adjusted to accommodate all types of loads and weight variables. There are other options out there.
    DG92071 likes this.
  9. Feb 27, 2020 at 12:39 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Don't tell anyone but I've been towing my TT (5,500lbs loaded) without a swaybar for 5 seasons and 5,000ish miles and the truck hasn't tipped over on me yet.
    You really shouldn't be pushing the truck to the point where a swaybar comes into play when towing. I wouldn't recommend this with stock suspension though.
    DG92071 likes this.
  10. Feb 27, 2020 at 10:20 PM
    chueflee
    Chue
    I was planning to get these shocks
    Bilstein Front/Rear 5100 Series Monotube Shocks
  11. Feb 27, 2020 at 10:27 PM
    DG92071
    DG92071 Well-Known Member
    I tow very heavy boats with no sway bar. I drive cautiously and intelligently whenever my truck tows. It's fine without the sway bar.
  12. Feb 27, 2020 at 10:30 PM
    DG92071
    5500+ boat towed, no sway bar, stock suspension with blocks and spacers - no problem except for the brakes before I changed them.
    I hope you upgraded your brakes because that was scary...
  13. Feb 27, 2020 at 10:49 PM
    chueflee
    Chue
    anyone know any good leaf springs that don't squeak
  14. Feb 28, 2020 at 3:47 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Here's my 2 cents based on over 30 years of towing just about everything with various trucks. Correct springs are more important than shocks because they carry the load. OEM Tacoma leaf springs are pretty weak, but a 3,000 pound boat won't have enough tongue weight to cause huge problems there. You might want to add something like a set of Timbrens which act as a progressive bump stop. I have them in my Tacoma and tow my 4,000 pound boat with no problems. (And I've towed significantly more with no issues.)
    Shocks dampen movement of the suspension. If your springs are wimpy, no amount of dampening is going to raise the rear end back up. You do need a decent set of heavy duty shocks, but they need to work with a decent set of springs.
    EnonEye and Muddinfun like this.
  15. Feb 28, 2020 at 6:41 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Just TRD pads with factory rotors. Trailer brakes get the job done.
    DG92071[QUOTED] likes this.
  16. Feb 28, 2020 at 7:28 AM
    chueflee
    Chue
    you mean coil springs? whats a good set of coil springs to go with the 5100 bilstein. I'm still planning to change the leaf
  17. Feb 28, 2020 at 7:30 AM
    chueflee
    Chue
    would the Timbrens work as good as air bags?
  18. Feb 28, 2020 at 12:38 PM
    Too Stroked
    Tom
    Here's a link to what I'm talking about. They work in conjunction with your stock leaf springs. They are not a coil spring.
    https://timbren.com/blog/products-page/tortun4l/
  19. Feb 28, 2020 at 12:39 PM
    Too Stroked
    Tom
    Air bags are pretty sweet, but they're more expensive, harder to install and overkill for what you're towing.
  20. Feb 28, 2020 at 12:42 PM
    coopcooper
    alberta canada
    I have timbrens and ive noticed they help when you hit a big ass dip in the road when towing, I have icon leafs too though and they don't sag that much.
