suspension going to be the same? lift kits??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trx680, Aug 11, 2015.
  1. Aug 11, 2015 at 4:35 AM
    trx680
    trx680 [OP] Member
    is the suspension going to be the same as previous?
    current lift kits going to be compatible with the 16s?
  2. Aug 11, 2015 at 6:52 AM
    rodeho
    rodeho Well-Known Member
    Rob
    Pensacola
  3. Aug 11, 2015 at 10:44 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Didn't you hear Swears?
    Completely different. Nothing in the suspension will be the same. Different springs, different shocks, different ball ends, etc. All different
  4. Aug 11, 2015 at 11:01 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    My guess is the mounting will most likely be the same. Look at the 2014 Tundra.... It has basically the same truck frame and body but modified.
  5. Aug 11, 2015 at 11:24 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The only thing I can confirm for certain is that the front lower control arm bolts and alignment eccentrics are larger, and there are some differences on the rear springs/axle. Most of it appears to be the same or very similar.
    There are changes to the truck (more than between the 2013 and 2014 Tundra, in my opinion), but it still is essentially the same truck as the 2015 with a new driveline, sheet metal and interior.
    Jeff
    because_wumbo-truck likes this.
