suspension guidance - handling washboard
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GONE FISHIN', Mar 6, 2022.
  1. Mar 7, 2022 at 6:13 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Digressive shocks will handle washerboard.
    Aworkinprogress likes this.
  2. Mar 7, 2022 at 6:45 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Just air down. It's 100% the first thing you should do.
  3. Apr 19, 2022 at 9:18 AM
    GONE FISHIN'
    GONE FISHIN' [OP] Well-Known Member
    northern front range CO
    21 ORAC
    thank you all for your replies. airing down does help a bit, going 6112/5160s with HS 3LAAL , we'll see. Will consider AG HHs if unsatisfied after upgrade.
  4. Apr 19, 2022 at 9:37 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Are your tires 10 ply e rated by any chance?
  5. Apr 19, 2022 at 9:40 AM
    GONE FISHIN'
    21 ORAC
    No, stock OR shiz.
  6. Apr 19, 2022 at 12:58 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yep, i've now seen an empty gen3 trd bounce around bad on my pot hole filled dirt road. I've taken the same road many times unloaded getting similar results. Just installing the tonneau cover back on helps. Its actually pretty good with a few hundred lbs in the bed.
  7. Apr 19, 2022 at 1:02 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Slow down?
    zoo truck likes this.
  8. Apr 19, 2022 at 1:09 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I got the trd lift done :anonymous: That weekend I hit Death Valley… hunter mountain rd to racetrack playa, Titus canyon etc truck flew through it like what washboard? I have since replaced the 1” block with a progressive aal from toytec. Which gave it about 2” instead of 1 so the rake is back. If the truck is unloaded it gets pretty lofty in the back end. Decked system plants it.
    GONE FISHIN'[OP] likes this.
  9. Apr 19, 2022 at 1:17 PM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    Would those help with a different spring pack? I'm getting Icon RTX installed and not sure if they will come with new hangers or not? My guess is not but cannot find anything specifically saying one way or the other.
  10. Apr 19, 2022 at 2:10 PM
    05 4x4
    05 4x4 Well-Known Member
    2020 trdorac stock with slightly bigger K02's - Went from a paved potholed road to a washboard on the side of road with two dirtbikes in the back and shockingly immediately lost traction in the rear. It was easily savable but I was suprised.... my 2nd gen didnt do the same in the same conditions.... might look into these AGHH's! Thanks!
  11. Apr 19, 2022 at 11:42 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The Icon's will not come with hangers or shackles, Archive Garage makes both as much better replacements though.
  12. Apr 20, 2022 at 3:28 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Well a couple folks are on it. First thing is to air down. We have a ton of roads with heavy think wash boards here in Central FL. While I love all of my archive garage installs, airing down is your best friend. Especially if it's a washboard road you will be traveling on for miles at a time. Many different options on compressors or power tanks. It all comes down to how much you want to spend and what is your patience level with the fill / empty routine. My patience level is garbage most of the time so I'm set up for as quick as possible. To deflate I have Apex design precision deflators. Inflate is a dual ARB compressor along with remote chucks to the passenger / driver bedrail on the truck bed. Works like a charm. I would go with a power tank if I did not have lockers. Power tanks are much quicker.
  13. Apr 20, 2022 at 5:40 AM
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    I installed Fox 2.5 from Accutune last summer. Just did the Hammer Hangers and that seemed to have really cleaned up the ride. I rarely offroad so I haven't driven a washboard since the HH install, but the ride on crappy pavement really feels different. Almost like I added a lot of weight to the bed. The install was a huge pain in the butt with drilling rivets but worth it.
  14. Apr 20, 2022 at 5:57 AM
    zoo truck
    None
    Imo, the best way to run on washboard roads is having more progressive spring action, along with the shock valving to match. The stock springs begin too stiff when unloaded....they need to start softer, and firm up in the last 2/3 of the suspension's travel. Having rear coils would probably be the next best thing, but then you'd have a payload issue not being able to carry as heavy a load.
