Suspension height: base vs. Off-Road vs. Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mooch91, Jun 15, 2015.
  1. Jun 15, 2015 at 6:35 PM
    mooch91
    mooch91 [OP] Well-Known Member
    PA
    2012 Tacoma AC SR5 4x4
    All,
    Tried the search on this one and saw all the comparisons of options, lockers, scoops(!) between the models, but didn't find info on the one question I have.
    Are there differences in suspension height (specifically wheel/tire clearance) between the three models?
    The reason I'm asking - if someone with a Sport or Off-Road, with stock suspension, has no issues with a particular wheel/tire combination, is there a good chance that I will have no issue with the same combination on my base model SR5? I know there are a lot of factors to be looked at (tire style, pressure, mudflaps, etc.), but I figured if they were at least riding at the same height, I'd have a good chance at making a good comparison with a setup someone has already proven.
    Thanks!
  2. Jun 15, 2015 at 6:57 PM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    Yup, they are all the same. Might be a very slight difference between a truck with a lot of miles and a brand new truck, but not much. If it fits a stock sport or OR it should fit yours just fine.
  3. Jun 15, 2015 at 8:10 PM
    Pigpen
    Dan
    Northwest Montana
    Yep, all the same. If you want to pay too much to have Toyota lift it for you, they make the Baja and Pro :crapstorm:!
    Lord Helmet and VandalTaco like this.
  4. Jun 15, 2015 at 8:11 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
  5. Jun 16, 2015 at 3:03 AM
    mooch91
    PA
    Thanks guys!
