Suspension help and advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mavicair87, Apr 24, 2025.
  1. Apr 24, 2025 at 2:05 PM
    Mavicair87
    Mavicair87 [OP] Member
    Jose
    2023 Gray Tacoma trd off road 4x4
    Ok so I am sure alot of folks have recommendations on this matter so here it goes. I have a 2023 tacoma trd offroad and want to do a 2in lift. This is what I have in mind 6112 billstein up front with stock spring in rear either 5160 or 5100. With the icon add a leaf pack....
    Next option is 5100 all the way around with the 1.5 in block in the rear. I live in wilmington nc and don't really plan on doing alot of harsh off roading and don't have any extra weight on my bed. I have stock 16 in rims and don't really wanna get bigger rims yet. Any way that's it any advice would be helpful thanks guys
  2. Apr 24, 2025 at 2:24 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Nice.
    I've got the 2" 5100 lift, but only a 1" block in the rear. It sits perfectly level all around. I dont usually carry extra weight, hence I didn't see a need for a AAL. No regrets.
    You could keep your 16" rims, and get bigger, more aggressive tires.
  3. Apr 24, 2025 at 2:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Sounds like a good plan. Some time in the Suspension forum you might find helpful too..
    71tattooguy and Josephray70 like this.
  4. Apr 24, 2025 at 2:50 PM
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    a lot of people say that the 5100s ride a lot better for daily driving. But I would say that also depends on what sort of clip setting each one goes with. The more you preload the spring, the harsher ride you will experience. I went with the 6112 but only preloaded it at 1 inch and a 3/8 spacer to get the other inch. I also wanted a 2 inch lift, did a lot of research and decided against maxing out the circlip. But I do like to off-road so that’s why I went with these shocks over the 5100s. And even though they are considered a stiffer shock, they ride quite nice in my opinion. Probably not as nice as the 5100s. I did go with the 5100s for the rear. But they’re just shock Absorbers. So there wasn’t a big difference from stock. I did install them a week prior to the 6112 because they came first.
  5. Apr 24, 2025 at 2:55 PM
    MGMDesertTaco
  6. Apr 24, 2025 at 3:13 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  7. Apr 24, 2025 at 4:51 PM
    Mavicair87
    Jose
    Tocamo did you do a upper control as well?
  8. Apr 24, 2025 at 4:52 PM
    Mavicair87
    Jose
    Did you do the upper control arms as well?
  9. Apr 24, 2025 at 5:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    To tag, it's @username, such as @Mavicair87
  10. Apr 24, 2025 at 5:12 PM
    MGMDesertTaco
    2" and under usually doesn't require aftermarket uca's.
  11. Apr 24, 2025 at 6:18 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Nope. Nor did I replace the front springs (as per Bilstein recommendation).
    HLSATRK likes this.
