suspension help
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Jun 12, 2009.
  1. Jun 12, 2009 at 9:33 AM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    hey guys in order to get like a 4 inch lift it requires a new crossmember is cutting the cross member good on our 1st gen's or no????? am i going to have problems later on or should i just get a 3" coilover kit instead
  2. Jun 12, 2009 at 10:35 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    2-3" suspension and 1-2" BL is better IMO. But what are you using the truck for? Off roading, mall runner, DD? What size wheels/tires are you gonna want to run? I doubt PreRunners requires the removal of the cross member only 4X4's.
  3. Jun 12, 2009 at 10:38 AM
    socal19
    California
    well see i offroad a little not to crazy and go through tuff stuff. i also go out to pismo beach and sand. i dont do any wheeling or anything like that i heard if you go more than 3 inches witha a cheap set up u can wear out ur cv joints but i dont know. i also heard a bl is not good also???
    i also wanna run 33's bfg at ko
  4. Jun 12, 2009 at 10:50 AM
    sirsaechao
    Tim
    Commifornia
    Anytime you alter your suspension past stock geometry you are putting everything at risk. I suggest either Bilstein 5100 Adjustable front shocks set at 2.5" w/ trimming to fit those 33's or ToyTec/OME coil spring lifts. It all depends on the budget you have planned for it as well. You can go cheap with hockey puck spacer lifts and rear blocks to coil spring lifts to drop bracket kits to coilovers. Then blocks for the rear to shackles to AAL's to full custom leaf packs. I say figure out a budget and what you want to use your truck for. Ideally you want to run 4" to clear 33's but most people get away with 2.5-3" suspension lift w/ 33's or 285/75R16's w/ trimming aka pinch weld mod.
    Edit: 1-2" BL is save to run.
