Suspension Help
Discussion in 'Suspension' started by feelinducky, Aug 19, 2017.
  1. Aug 19, 2017 at 10:33 AM
    feelinducky
    feelinducky [OP] Member
    Rick
    Sacramento
    01 4WD
    98 3.4L 4X4 Ext cab with a shell. Approx 125K miles 5 speed
    New 31" Toyo At's
    I have been researching suspension for my Tacoma but I have a few questions that I just can't seem to find the answers to.
    My truck is a daily driver and I hunt and fish in the Sierras. I'm not running the Rubicon but run some of the 4 wheel drive trails. I would like to keep the truck at the stock height and improve the suspension.
    I need to replace all the shocks + rear leaf springs they are flat with a slight bow where the axel sits. So far this is what I'm considering
    Bilstein 5100's on all wheels for sure.
    I'm trying to figure out if I add the springs can I keep it close to factory height without having to put spacers on the differential. If it does raise it 1-1.5 inches will it look ok with my current tires?
    Springs: Front OME 2880
    Rear: Wheelers 5 leaf spring set.
    If you have any other ideas I'm open to them.
    Thanks for the help.
  2. Aug 29, 2017 at 6:59 AM
    feelinducky
    Rick
    Sacramento
    01 4WD
    So an FYI for all who read the post.
    I ended up with 5100's all around,OME 2880 springs on the front and new Wheelers 4 leaf packs from Wheelers Off Road. Before I started I was 21"-21.5" from center of hub to the fender. After I was done I raised it an inch all the at around. Pretty straight forward job, took me all day but got it done. Thanks to the guys at Wheelers for the advice.
    tcjacado likes this.
