Suspension Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Highrob, May 16, 2019.
  1. May 16, 2019 at 2:59 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yep, still fully assembled. You just need to do a straight swap, don't worry about any spring compressing. That is only needed when removing the spring from the coilover. Just take the Fox out (3 nuts on top, one bolt on the bottom) and slide those in.
    Highrob[OP] likes this.
  2. May 16, 2019 at 3:42 PM
    Highrob
    Highrob [OP] Well-Known Member
    Rob
    Los Angeles
    2019 Tacoma Off-Road
    I don’t need to take any bolts off from the lower control arm to the frame? Or the two bolts that go from the lower control arm knuckle
  3. May 16, 2019 at 8:53 PM
    Tarheel22
    Tarheel22 Well-Known Member
    Raleigh, NC
    2012 Silver TRD Sport 4X4 DCLB
    none yet
    Just remove the 3 bolts at the top of the strut assembly and the single bolt at the bottom of the strut assembly, remove the sway bar bracket on the side you are working on then Loosen the two bolts that attach the lower control arm, this will allow the lower control arm to drop so you can remove the strut assembly. Replace the unit with your stock unit and you are done. since the vehicle is totaled you don't need to worry about messing up anything with the alignment. Of course, make sure you jack up the truck safely and use jack stands.
  4. May 18, 2019 at 9:33 AM
    Highrob
    Rob
    Los Angeles
    Update: I was able to swap out my front and back shocks with the stock suspension successfully. Thanks for the help guys
    HIYota, Sae68 and Tarheel22 like this.
  5. May 18, 2019 at 9:37 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Sweet! Good job!
    Highrob[QUOTED][OP] likes this.
