Suspension install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45NORTH, Feb 19, 2020.
  1. Feb 19, 2020 at 6:30 PM
    45NORTH
    45NORTH [OP] Well-Known Member
    Minnesota
    2015 DCSB TRD OR
    OME BP-51, OME AAL SPRINGS, DK LCA, DK UCA, SLEE ARMOR, CURRIE RE, ALU-CAB EXPLORER CANOPY, ALU-CAB GEN 3 RTT, FRONT RUNNER RR, WARN FRONT SEMI HIDDEN BMPR w/WARN Z-10s, AP REAR DUAL SWING BMPR
    Looking for an honest breakdown of time and involvement in full suspension install. I'm not the most mechanically inclined but I want to learn. Here's what I have. DK UCA's & LCA's, new gusseted spindles, front and rear OME BP-51 co's/shocks, Alcan Springs with flip kit and ICON bolt on bump stops......Ready, Set, Go.
    Johnny DemonT likes this.
  2. Feb 19, 2020 at 6:34 PM
    mx07gt
    mx07gt Well-Known Member
    somewhere between 4 hours and 5 days. I'm not kidding...it all depends if you have the right tools, mechanical aptitude and if everything goes out smooth. A simple stripped bolt could set you back hours.
    Going off your list, that is quite a parts list you have. I would definitely have somebody thats familiar with what's the task at least give you a hand.
    whatstcp and Chris(NJ) like this.
  3. Feb 19, 2020 at 6:38 PM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    One thought, I have heard that it is smart to gwt a second set of UCA arm bolts as the factory are easier to remove by cutting and then reverse installing the new? Ever come across this... What's your take?? Thanks
  4. Feb 19, 2020 at 6:47 PM
    KILLINTIME
    KILLINTIME Like a Villain
    I have done everything myself to my truck. The UCA Bolts were a bigger pain in the ass than anything else I did. I didn’t cut them though. Just take it slow and don’t get in a rush. Put penetrate oil on all your bolts before working on it. Learn how to piggy back a box end wrench to get more leverage and have a cheater bar. Cheater bar will help you get that axel nut off. It is rewarding working on your own truck. You learn something every time you work on it. Good luck and have some cold beer nearby!
    Rocksteady1 and DG92071 like this.
  5. Feb 19, 2020 at 6:49 PM
    KILLINTIME
    And obviously you can step by step everything your doing while watching Somebody else do it on YouTube. That will help you a lot too.
    DG92071 likes this.
  6. Feb 19, 2020 at 6:49 PM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    KILLINTIME likes this.
  7. Feb 19, 2020 at 6:52 PM
    KILLINTIME
    Yeah man!
  8. Feb 19, 2020 at 6:55 PM
    Muddinfun
    Muddinfun Well-Known Member
    Holy Crap! That's a metric shit ton of money. While it's all apart, you should definitely do the ECGS bushing, a new seal, and a Lexus clamshell drain plug. If the wheel bearings have over about 60K miles on them, I would replace them while it's all apart, as well as all the seals. I'm betting it's gonna be a good solid 2 days of work. Rusty bolts, needing more parts, etc. are going to put the skids on progress.
    DG92071, Johnny DemonT and whatstcp like this.
  9. Feb 19, 2020 at 6:59 PM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    47k on the truck. Little to no rust as it does not get driven much this time of year...damn salt up here is brutal so I commute in a beater. Thanks for the added suggestions @Muddinfun
    Muddinfun likes this.
  10. Feb 19, 2020 at 7:08 PM
    Muddinfun
    That's great news. It's going to be an awesome truck. So, I would still do the ECGS bushing, a new seal, and a Lexus clamshell drain plug. You're also going to need a new inner wheel bearing seal, because it gets pounded into the knuckle. There is a seal that runs next to it that is pounded onto the CV joint, but I wouldn't bother with that with your low miles. The suggestion to cut the UCA bolt is a good one. Then install the new bolt backwards. With your low miles and not driven in the winter, there's a possibility that the alignment cams aren't seized, but you should be ready to buy new ones if they are seized. Definitely step up and buy OEM alignment cams.
    whatstcp and Johnny DemonT like this.
  11. Feb 19, 2020 at 7:16 PM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    Holy sh#%....I've created a monster. Deep breath, I'll get there. Lol
    Thanks man.
    Island Cruiser and Muddinfun like this.
  12. Feb 19, 2020 at 7:31 PM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    Thanks Bubbles
    whatstcp likes this.
  13. Feb 19, 2020 at 7:43 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    My guess is 16 hours if you have someone helping part of the time.
    I replaced front coil overs, took apart new rear leafs, added a leaf to them, installed the leafs and new shocks in the rear with my brother in law helping a bit and it was 8 hours.
    Air tools and a lift would have cut off a couple hours.
    The extra parts you are replacing would probably cost another day.
    And If you come across some seriously rusted bolts and snap something, all bets are off.
    Sae68 likes this.
  14. Feb 20, 2020 at 3:59 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Nothing to add. Looks like you have all the advice you need, a beater as a 2nd vehicle so no time restrictions, and an eagerness to DIY. Some would've simply paid a shop..i usually find new challenges as an excuse to add new tools to my collection. Kudos OP:thumbsup:
  15. Feb 20, 2020 at 4:48 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I agree w/ this.
    whatstcp and 45NORTH[OP] like this.
  16. Feb 20, 2020 at 10:32 AM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    Tool list is a big one for me and aptitude. I'm learning daily and Im looking at a mid March install as time/work allows. Thanks all.
  17. Feb 20, 2020 at 10:38 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I did Kings, rear springs, UCAs, TC spindles, and ECGS bushing in 3 days. That includes an alignment. Good luck with your truck.
  18. Feb 20, 2020 at 10:41 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    with proper tools and not having to deal with any rusted/seized bolts easily be done in a weekend.
    45NORTH[OP] and Mully like this.
  19. Feb 20, 2020 at 11:03 AM
    45NORTH
    Minnesota
    2015 DCSB TRD OR
    Sweet setup man. Thanks for the input.
    Mully[QUOTED] likes this.
  20. Feb 22, 2020 at 8:07 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Jump in and have fun. The front end can be frustrating. Grab a bud light and start taking it apart. The front axle nut is damn tight, a good impact will make it easier. I've not done uca's but have done three front lifts. Getting the taller coil over in is a little frustrating. A floor jack makes all the difference. Watch the steel brake line to the caliper. It's fra gee lay. The rear is not bad. Contrary to earlier advice I do both at the same time. Take u bolts off, with a floor jack supporting the pumpkin, lower the rear axle then un bolt both rear leaves. Put the new ones in and bolt the axle back up with the u bolts and Bob's your uncle. As far as your going now you should do a u bolt flip as well. These trucks are pretty easy to work on and you'll be pretty proud of yourself for doing it yourself. intransigent post pics as you go.
