Suspension Issue on 08 Tacoma dbl cab
Discussion in 'Suspension' started by kansay, Jan 6, 2011.
  1. Jan 6, 2011 at 8:40 PM
    kansay
    kansay [OP] Well-Known Member
    dude
    Twin Cities, MN
    08 tacoma dbl cab 4x4 sport
    Bilstein shocks front and back.
    Hey guys, I've just put in my bilstien 5100 shocks and rear TSB done. I've having issue with my suspension now that it's much harsher than before. Meaning that the rises is way worsen than before. If I hit a pot hole or and uneven road with bumps, my car jerks and bounce left and right. Is anyone having the same issue I'm having. And I also have a vibration at speed of about 35 to 45 mph. I think that even with the new shock lift it should jerk my car that much and even going on uneven roads, I should still be able to control my car. anyone with info, please let me know cause it's frustrating me now. Thanks
  2. Jan 7, 2011 at 6:01 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Did you get an alignment after installing the 5100's?
  3. Jan 7, 2011 at 6:07 AM
    Tippett's TRD
    Tippett's TRD Well-Known Member
    Josh Tippett
    Lake Linganore, Maryland
    2010 Speedway Dbl Cab L/B 4x4
    6" Pro Comp Suspension Lift, LEER Cap, NFAB Nerf Bars, Avid Off-road Bar, K&N Intake, Weathertech Liners, 2011 Grille, BedRug, Westin Taillight Guards, Tinted Windows, RedLine Hood Struts, Mag Lite Mod, Stubbie Antenna...
    A lot of people on here talk about the vibrations... not sure though w/ just billies. The jerking left and right is def not common though.
    ^^^Agree with him, you have an alignment?
  4. Jan 7, 2011 at 8:31 AM
    bigbeariuka
    bigbeariuka Well-Known Member
    Just installed new tires (general grabber at/2), 5100's set at 2.5 and add a leaf rear 1.5''. Now I feel like its floating on the road. Help
  5. Jan 7, 2011 at 8:57 AM
    TexasTacoma37
    What were your alignment specs? Do you have aftermarket UCA's?
  6. Jan 7, 2011 at 10:04 AM
    kansay
    dude
    Twin Cities, MN
    Yes, I did get an alignment done after the 5100's.
  7. Jan 7, 2011 at 10:10 AM
    kansay
    dude
    Twin Cities, MN
    Yes I did. When I drive the car through uneven rough streets, I feel the car just jerks around and seems like the suspension is way too stiff and it should still give me a comfortable rides after putting in the 5100's. If I hit a road bump on the freeway, my car seems to roll or bounce uncontrollably, any thoughts would help.
  8. Jan 7, 2011 at 10:45 AM
    TexasTacoma37
    Hmm did you get a printout of the alignment specs sheet? Sounds like your caster may be out of whack.
    Do you have stock UCA's?
  9. Jan 7, 2011 at 11:06 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Seems odd...
    I have 5100's set at 2.5 and a 2" AAL w/ stock UCA's. They set my caster at 1.9 and it rides great. It wanders a tad more than stock but IMO my truck feels much tighter after the new suspension.
    Post your alignment sheet numbers.
  10. Jan 7, 2011 at 11:12 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    Think about it.. your front springs are compressed so much at 2.5 that it's going to be harsh. The spring needs some give for it to compress and extend to keep the tire on the ground. I wouldn't lift it any higher than 1.75 with stock springs... I had mine at .85 and the ride was similar to stock... less body roll, stiff but not harsh.
    try lowering the height and see if that makes a difference, if so you on the right track.
  11. Jan 7, 2011 at 11:18 AM
    macgyver
    Brad
    Canton, GA
    I'm at 2.5 with mine and the ride isn't harsh at all. Slightly firmer than stock, and I mean slightly. I have ridden and driven in some harsh vehicles before. I used to be in the performance car scene. I had a honda accord w/ a 3" drop so I know harsh suspension. My buddy used to have a subaru WRX with JIC Magic coilovers. I would make sure I peed before I rode in his car because it was sooo stiff it would make you have to pee if you had the slightest amount of liquid in your bladder.
  12. Jan 7, 2011 at 11:19 AM
    papabear050
    Hmmm... could be you have a set of bad shocks then?
    That would suck.... Push down on the corners of your truck and see if the suspension pops the truck back up in a timely manner.
  13. Jan 7, 2011 at 11:48 AM
    kansay
    dude
    Twin Cities, MN
    Hey, yes my caster is set at 1.9 too and I did the same setup as you did. 2.5 and TSB in the back and stock UCA's. Just don;t know why my car is riding this way at all.
  14. Jan 7, 2011 at 11:50 AM
    kansay
    dude
    Twin Cities, MN
    When I push down on the front corner of the car it goes up and down slightly, not much.
  15. Jan 7, 2011 at 12:00 PM
    macgyver
    Brad
    Canton, GA
    You guys also have pretty shitty roads up there compared to GA so maybe thats the issue. I was in minneapolis last May on business and the roads were definitely worse than down here.
  16. Jan 7, 2011 at 12:05 PM
    TexasTacoma37
    Are the spring perches installed correctly? It's a common mistake on the billys for people to install them upside down. That would preload the springs a lot more and give you a stiffer ride.
  17. Jan 7, 2011 at 12:15 PM
    kansay
    dude
    Twin Cities, MN
    Yes and correct, our roads are here are just ridiculous due to the winter snow and stuff. All the freaking payments is like crap here and there's pot holes and uneven payment every where you go. But the weird things is that I have a friend that drives a 09 tacoma dbl can 4x4 and he has the same setup as mines and it runs really smooth than mines, just odd.
  18. Jan 7, 2011 at 12:16 PM
    kansay
    dude
    Twin Cities, MN
    I double check mines and I know I had them on correctly.
