Suspension Issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kchur00, Jun 19, 2023.
  1. Jun 19, 2023 at 6:21 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    2013 Double-Cab Tacoma, Base, 2.7 4-cyl, 2WD
    Greetings fellow Taco owners. 1st time post here.
    I'm having a vibration issue with my suspension it seems. I feel it over 40 MPH in my steering wheel and it gets worse around 60+ MPH. I feel it more in the steering wheel itself and there is some slight play in the steering wheel.
    New tires in Feb. At first thought it was a balance issue, but had them rotated, re-balanced. Has proper air. No issues or defects seen with the tires. No issues with alignment. All this done by very reputable shop.
    Had it off the ground and tried to shake/move the wheels and there's no movement there.
    My wife drove it and said the ride feels "bouncy".
    I'm not noticing any weird sounds.
    Don't see any cracked boots.
    My guess is the struts may be starting to go bad?
    Could anyone else give me any insight on things to check before I start throwing parts at it?
    ZMan2k2 likes this.
  2. Jun 19, 2023 at 6:23 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Are you noticing any dark spots on the shock bodies, like oil leaking out? Are they original shocks, or have they been replaced before? If so, when? Have you ever replaced the carrier bearing/ u-joints?
    We have the year, but what’s the mileage on your truck?
  3. Jun 19, 2023 at 6:35 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    Thanks for the reply.
    None that I have noticed so far with last inspection, which was about week and half ago, but I'll need to check again. The vibration was noticeably slightly worse this morning on way to work.
    Truck has 160k miles. Entire strut assemblies on both sides were replaced 02/2020. I have not replaced the carrier bearing or u joints. Did replace passenger side upper/lower control arms and sway bar link because of bad boots and bad ball joints recently. Alignment was done afterwards.
  4. Jun 19, 2023 at 6:42 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Is it a steady rhythmic bouncing that gets faster the faster you drive or just a random bounciness?
  5. Jun 19, 2023 at 6:50 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Is your truck 4 wheel drive? If so, maybe you just need to grease your driveshaft. Easy to do and inexpensive:notsure:
  6. Jun 19, 2023 at 6:50 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    The vibration in the steering wheel seems steady. Doesn't seem to necessarily get faster with higher speed, just more noticeable/pronounced. The bounciness is more so with bumps, etc.
  7. Jun 19, 2023 at 6:51 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    More info is better lol - It's a 2 wheel drive
  8. Jun 19, 2023 at 6:56 AM
    10thMTNgrunt
    2013 TRD Sport
    I could be wrong but I think the 2 wheel drive Tacomas have sealed driveshafts so no greasing is necessary.
  9. Jun 19, 2023 at 7:42 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    My goto first would be carrier bearing/ u-joints. At 160k, they’re due for retirement. Check the play in them, grab the DS and twist, if it twists or clunks, u-joints. If the carrier has more than 1/8” play, it’s fading fast.
  10. Jun 19, 2023 at 7:51 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    definitely the carrier bearing and at the same time do all your ujoints, great maintenance or something you love
    Kchur00[OP] and ToyoTaco25 like this.
  11. Jun 19, 2023 at 8:06 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Does it change at all when you apply the brakes or make a slight turn? Is the steering wheel moving back and forth when it happens? Hoping to get a clue as to whether it’s due to the front wheels oscillating. I assume you had the alignment shop do an inspection of the components in the front suspension?
    If you’re not getting the vibes thru the wheel more than the body/seat, I’d have a hard time pointing at the u-joints or carrier bearing first. Doesn’t mean they’re not due, tho. ;)
    bkhlrTaco's likes this.
  12. Jun 19, 2023 at 8:07 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Does it change when you apply the breaks?
    I would look into your front hub assembly, replacing them (and CV pin bearing) helped with my steering vibration.
    I had u-joints go and had my carrier bearing replaced, it helped with vibration, but it was more of a general vibration, not pronounced in the steering wheel.
  13. Jun 19, 2023 at 8:34 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just to clear things up. Your truck doesn't have struts.
    You have a coil over shock absorber.
    With Struts there would be no Upper Control Arm.
  14. Jun 19, 2023 at 8:39 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Steel or aluminum wheels?
  15. Jun 19, 2023 at 9:13 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Questions;
    Did the vibration start after you put new tires on in February?
    You say they have been rebalanced, is there a lot of weights on one or both of the front wheels to get them balanced?
    Your wife said the ride feels "bouncy." Just want to make sure here because my wife would call it bouncy when the ride is actually rough.
    The condition of the front shocks (and rear) can be easily checked. With the vehicle level, push down on each corner (one at a time) and quickly release. The vehicle should return with some stiffness. If it continues to bounce, chances are you may have a bad shock and would need further evaluation.
    Since your truck is 2WD with the 2.7 I doubt if the coils or springs on the front of your truck are shot and need to be replaced. Now your rear leaf springs could be a little flat, but that's a different subject and not the issue here.
    EDIT:
    One more question; Are your wheels steel or alloy?
  16. Jun 19, 2023 at 9:48 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    No change when braking other than below 40 MPH it's not noticeable. No change with turns that I've noticed.
    It does somewhat move back and forth, but not much. It's always had some slight play in the steering wheel since I've had it. I got it with 22k miles.
    But, yes. They checked over the suspension when they did the alignment.
  17. Jun 19, 2023 at 9:54 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    It did start after the new tires, but this vibration stated maybe 3 weeks ago. I went with a different tire this time, too. I was using Kumho tires, but I had a problem with sliding in wet weather. I had them put on tires more suited for wetter weather.
    I'm not sure what a lot of weights would be, but there's probably a 3.5 inch thin strip of weights stuck on the inside of the wheels.
    They are aftermarket 17 inch alloy wheels.
  18. Jun 19, 2023 at 9:56 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    it would be helpful to post make and model of tire along with whether it’s a p metric or LT tire.
    What aftermarket wheel are you using and which lug nuts?
  19. Jun 19, 2023 at 10:04 AM
    Kchur00
    Kchur00 [OP] Member
    Kellen
    Alright.
    Nexen N5000 Platinum tires, 235/60 R17
    Wheels are MSW T22. Used the lug nuts and centering rings Tire Rack sent me. Nickle plated lug nuts.
  20. Jun 19, 2023 at 10:06 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    With all that new front end work done I would start with a torque wrench and make sure everything is tight, again.
    Is it lifted? Just lifted mine 3" and everything changed as far as how it handled.....even after the alignments. Before alignment the lift had front tires toed in so far the steering was ultra sensitive over bumps. Would pull violently one way or the other.
    After the lift I started hearing clinking and clanking over bumps. Had to get back underneath and retighten swaybar/linkages and put a swaybar spacer in.
