suspension issues with 5100's hitting coil
Discussion in '1st Gen. Tacomas (1995-2004)' started by ixsanctifiedxi, May 4, 2012.
  1. May 4, 2012 at 8:50 PM
    ixsanctifiedxi
    ixsanctifiedxi [OP] II corinthians 5:21
    Aaron
    Lynchburg, VA
    02 3.4L Double Cab 4x4
    Deck Plate Mod, OME 881's on 5100's set to 0", Dakar leafs in the rear with 5100's...
    Just as the title says, my Driver's side front shock piston is hitting the coil on extension... is there anyone out there having this same issue? also any suggestions on getting it fixed without pulling the whole strut assembly off? any input would be great... hoping to get it taken care of tomorrow
  2. May 4, 2012 at 8:52 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Can you take some pics of the issue and post it?
    Double check if you assembled your struts and coils correctly. Its easy to accidentally flip the coil seat throwing off everything.
  3. May 4, 2012 at 8:53 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    isnt the piston in the actual shock body? if your piston is out you might have a bigger issue than it hitting the coil
  4. May 4, 2012 at 8:54 PM
    mentose457
    mentose457 Well-Known Member
  5. May 4, 2012 at 8:55 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    that's crazy. something's way wrong. post up a pic.
  6. May 4, 2012 at 9:02 PM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    it may not be the piston... [​IMG] this was them before I put them on.... it's not the fatter body of the shock, but the thin bar that runs up to the top of the strut...
  7. May 4, 2012 at 9:04 PM
    08pretaco
    az
    the shaft? where is the collar that is supposed to support and hold the coil?
  8. May 4, 2012 at 9:05 PM
    08pretaco
    az
    the collar i am referring to is the ring around the shock in this picture
  9. May 4, 2012 at 9:05 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    The collar is gone man! How did you get them in the truck?!?!
  10. May 4, 2012 at 9:06 PM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    it's set at 0"
  11. May 4, 2012 at 9:07 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Theres nothing holding the coil on the shock. Does the coil move around??
  12. May 4, 2012 at 9:07 PM
    08pretaco
    az
    where is the support though? ok so you have the snap ring in but your still missing the coil support that goes over the snap ring
    look at the pic i posted, where is that piece? the piece right above the guys finger
  13. May 4, 2012 at 9:12 PM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
    oh that's on there... it's a black one so it blends in with the springs...
  14. May 4, 2012 at 9:12 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Heres a good pic of what hes talking about.....That plate holds the coil and strut assembly together
  15. May 4, 2012 at 9:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    FWIW, the spring perch is installed upside down in this pic, and would be very dangerous if installed like this.
    The spring perch is there and installed correctly, it's just black instead of silver on the newer 5100s. I can see it
  16. May 4, 2012 at 9:12 PM
    ixsanctifiedxi
    Aaron
    Lynchburg, VA
  17. May 4, 2012 at 9:12 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Do you have a better pic of what your talking about??
  18. May 4, 2012 at 9:13 PM
    08pretaco
    az
    can you photoshop an arrow to where you are having the issues, hard to tell from the pic
  19. May 4, 2012 at 9:14 PM
    08pretaco
    az
    thanks, generic google picture but yes thats good to point out! thanks KPT
  20. May 4, 2012 at 9:17 PM
    TexasTacoma37
    No worries Ollie I just didn't want someone using that for reference on an install. I've seen it installed upside down probably a dozen times on here, as I'm sure you have. Such a common mistake.
