Suspension Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeyOliveri, Dec 12, 2019.
  1. Dec 12, 2019 at 8:04 PM
    JoeyOliveri
    JoeyOliveri [OP] Active Member
    Joey
    2014 White TSS Tacoma
    DBCustomz Grille 18x9 Fuel Assaults 305 60/r18 116s Nitto Terra Grappler G2s 3” Rough Country Lift JBA UCA’s Spyder Headlights and Taillights OEM Audio Plus 12” Sub AuxBeam 30” Bumper Light Bar
    Hey guys,
    Running into some issues with the truck. Driving funny lately, most noticeable thing is the steering wheel. Seems to be extremely tight and when making turns, it almost wants to push back down to stay straight instead of letting me turn, if that makes sense. I’m thinking its my wheel bearings which would make sense; I had my tie rods, UCAs, Lower Control Arms and ball joints replaced about a year ago so I don’t believe it could be that.
    My camber is still in alignment and everything seems okay, but feels like the wheel bearings because its mostly when i am moving my wheel drastically when I feel the “pressure” you could call it, just feels extremely heavy, almost like its fighting me wanting to turn.
    Lastly, sometimes ill be driving and the steering will feel loose but as i drive and kind of wiggle my steering wheel, it tightens back up.
    If anyone has had the same issue or knows what it could be please feel free to leave a message below.
    Thanks guys!
  2. Dec 12, 2019 at 11:35 PM
    tcjacado
    tcjacado Well-Known Member
    Could be power steering related.
    How is the fluid in the reservoir, any wet stains on the inner tie rod boots?
    Edit... clean the screen in the bottom of the reservoir. Is the fluid nice and clear or is it almost black?
  3. Dec 13, 2019 at 1:58 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I wonder if it's the intermediate shaft issue. I had this happen over the summer, and lubed it up with WD a few times, let it soak, and then hit it with some lithium grease, and haven't had any issues since.
    Check this thread:
    https://www.tacomaworld.com/threads/stiff-steering.122153/
  4. Dec 13, 2019 at 2:36 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Looks like you have had a lot of suspension work for a 2014.
    The intermediate shaft issue usually the steering is tight, then normal, then tight , then normal as you turn the wheel.
    I think if it were the wheel bearings you would have many other issues popping up if they were worn to the point of effecting the steering.
    JoeyOliveri[OP] and Muddinfun like this.
  5. Dec 14, 2019 at 10:14 AM
    JoeyOliveri
    Joey
    Hey bud, appreciate the response. Drive shaft looks in good condition, still just greased her up. Going to be putting the truck on stands and testing for play soon. Thanks for everyone who replied!
  6. Dec 14, 2019 at 10:14 AM
    JoeyOliveri
    Joey
    Just lubed it up, seemed to be in good condition already. Tire seems slanted at angles which is odd, not quite sure what the deal is. Gonna be putting her on jacks soon. Thanks!
  7. Dec 14, 2019 at 10:15 AM
    JoeyOliveri
    Joey
    Just flushed the steering fluid, put some transmission cleaner and then re applied new DEX 3 steering fluid, so that is taken care of. Still having issues. Thanks for reply!
  8. Dec 14, 2019 at 10:16 AM
    JoeyOliveri
    Joey
    Difficult to turn in both directions, going to be putting the truck on a lift here soon. Will let you know the outcome. Thanks!
  9. Dec 14, 2019 at 10:24 AM
    tcjacado
    Sounds like the rack is dying or the ps pump is.
  10. Dec 14, 2019 at 10:25 AM
    JoeyOliveri
    Joey
    Truck only has 74k miles which is my concern. Wasnt lifted until 55k, cant see it being too bad.
  11. Dec 14, 2019 at 10:31 AM
    tcjacado
    Did you clean the screen in the bottom of the reservoir? That screen gets gunked up and reduces the flow of fluid.
  12. Dec 14, 2019 at 10:35 AM
    JoeyOliveri
    Joey
    Didn’t see any screen, any pictures to help identify it? Just cleaned out the reservoir itself for the fluid.
  13. Dec 14, 2019 at 10:38 AM
    tcjacado
