Suspension lift "extras"
Discussion in 'Suspension' started by Mainmoe02, May 17, 2013.
  1. May 17, 2013 at 10:34 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'm trying to make sure I Order everything I need when ordering my suspension upgrade. I have a stock 2001 Tacoma 3.4L 2WD TRD double cab.
    Here's the suspension I'm getting...
    - Bilstein's 5100 adjustables for the front
    - Eibach 3" coils for front
    - Bilstein's 5125's for the rear
    - OME 2.25" leaf packs for the rear
    Now here's the list of all the extra equipment needed to install everything properly...
    -Upper Control Arms- for all those alignment issues.
    -Extended rear brake line
    -Longer U-bolts
    -Greasable Shackles
    -Greasable main eye bolt
    -Bushings
    -Brake proportional valve bracket
    -Exhaust relocation bracket
    That's everything I plan to order
    If you notice I don't have something on my list that I WILL NEED please let me know. Or if you see something on my list that I DONT NEED, please let me know.
    Thanks in advance!
  2. May 18, 2013 at 7:45 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Since your are Gen1 you most likely can get away with your stock UCA's. While you are added I would consider stainless front brake lines too. Not needed but a good upgrade over the stock rubber lines. Other then this you are golden.
  3. May 18, 2013 at 7:52 AM
    medic2230
    Murph
    Bama! Roll Tide
    Don't the 1st gens have a center bearing on the driveshaft too?
