Suspension lift for 3"
Discussion in 'Suspension' started by Polowhitfoot, Nov 18, 2008.
  1. Nov 18, 2008 at 8:42 PM
    Polowhitfoot
    Polowhitfoot [OP] Member
    Colorado
    4x4 TRD
    I am fricken' stoked! I think I figured it out. I have an 02' Tacoma TRD and am looking at getting the Camburg coilovers for the front, Deaver lift springs with the Biltstiens 5100 for the back. Included in the package would be the Camburg upper arms. As for the wheels/tires, I plan on getting some 285/75/16 BFG's with 1.25-1.50" spacers. I'm on the line with the differential drop, but for the money, it seems like a no-brainer.
    I'd like to get some feedback on any other parts that I should be buying in order to make this work. It will still be my daily driver and I will have a spare set of wheels/tires for the winter time. Any other suggestions would be greatly appreciated! I love this forum!:D
    http://www.demello-offroad.com//cat...id=66&osCsid=a952ca890d8bdc0ef6a766222cb87f8e
    How about the Donohoe rear resevoir shocks? Are they worth the extra couple hundred over the Bilstiens?
  2. Nov 18, 2008 at 9:06 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Sounds like you have everything covered! Are you running the tires on the stock rims? I am running the 285 BFG M/T KM2s on stock rims and I just put on 1.25" SpiderTrax spacers.
    One thing you're gonna need is a new way to jack up your truck in the event of a flat... :)
  3. Nov 18, 2008 at 9:52 PM
    Polowhitfoot
    Colorado
    4x4 TRD
    SWEET!:hungry:
    I didn't think they would fit on stock rims, so was planning on keeping the stock rims and tires for 'winter' driving and would look into getting different rims for the bigger tires.
  4. Nov 18, 2008 at 10:24 PM
    alexamado
    alexamado TEXMEX TACO
    TEXAS
    2006 PRERUNNER TRD SPORT
    885 OME Coils w/ OME N140S Shocks, Rear TSB w/ Rear AAL, Rear 5125 Bilstein Shocks, Westin Ultimate Bull Bar w/ KC Slimlites, Westin Running Boards, Roll n Lock Retractable Bed Cover, AVS Bugflector II
    I never even thought about that :confused: Do you know a place to get new jack?
  5. Nov 18, 2008 at 10:59 PM
    LonghornTaco
    Minnesota
    A lot of people here use the Hi-Lift jack. You can find them online and some people have mentioned a few retail stores, but I can't think of them off hand. Just do a search and you'll find it pretty easily.
    But one thing to keep in mind with the Hi-Lift hack is that you need some sort of jack point. I ordered a set of sliders from All Pro Offroad (hopefully here this week!!!) and that's what I'll use. There may be a couple of other options, but you'll need to check that out.
    Also, it's very easy to modify the spare tire well under the truck to allow for a full size spare if you run 285s. It's in the Cheap/Free Mods section.
  6. Nov 19, 2008 at 2:08 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    My stock bottle jack lifts my truck just fine.... :D
  7. Nov 19, 2008 at 6:57 AM
    LonghornTaco
    Minnesota
    Really? I didn't think it would go up that high...
  8. Nov 19, 2008 at 3:07 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    You can store Woood or Metal Blocks in your Spare tire to help the bottel Jack out a bit. It give it a few inches start if done right.
