Suspension Lift help
Discussion in 'Suspension' started by superhedgey, Dec 14, 2016.
  1. Dec 14, 2016 at 11:26 AM
    superhedgey
    superhedgey [OP] Member
    Brandon
    2015 Toyota Tacoma Prerunner 4 cylinder
    None
    i am looking to lift my 2015 Tacoma Prerunner 4 cylinder. I have been doing some reading and am lost. I read I should go with a suspension lift. But what should I go with. I don't want a cheap lift. I don't mind spending the extra cash for what I want. Can someone help direct me?
  2. Dec 14, 2016 at 11:35 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    What kind of budget are we working with realistically? Are you wanting a more high performance setup, or a basic lift to provide tire clearance?
  3. Dec 14, 2016 at 11:45 AM
    superhedgey
    Brandon
    None
    It is more for the look. It's not 4x4 so I won't be off-roading. I have a quote from someone where I live for Pro Comp Suspension 65205K. He said about $450. If their is a better option I would rather go with that. I can do up to $1000.
    YotaDan likes this.
  4. Dec 14, 2016 at 12:57 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    How many miles are on the truck? Stock shocks?
  5. Dec 14, 2016 at 1:41 PM
    superhedgey
    Brandon
    None
    15,000 stock shocks
  6. Dec 14, 2016 at 1:53 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Is that installed? I hope so because I can find the Pro comp Suspension(Spacer) Lift 65205k for under 300 online with a quick google search. If it is installed I guess $150+ isn't that bad if you cant do it yourself. I would install it myself and save the extra money though. Then again I would go with a real suspension lift and not a spacer lift. I don't know enough about 2nd gens to direct you to other options though.
  7. Dec 14, 2016 at 2:27 PM
    superhedgey
    Brandon
    None
    Yes the price he gave me included install. What is a real suspension lift? I am new to all of this and I want to do the best thing I can.
  8. Dec 14, 2016 at 3:09 PM
    SuperBad
    Dallas, TX
    Truck stuff
    To me a real suspension lift is new springs and shocks. The lift you listed adds in spacers above the front shocks and on the rear leafs to achieve the lift. Plenty of people run spacer lifts and they do the job of raising the truck and providing more clearance/space for larger tires.
  9. Dec 15, 2016 at 6:03 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    This is what I went with. I have no regrets at all!
    You also have the option of Maxtrac spindles. They are great for prerunners, but may provide more lift than you want. They also push your wheels out some.
    YotaDan likes this.
  10. Dec 15, 2016 at 7:28 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    If I were you, I would not go with the spacer and spend the extra $$ on Bilstein 5100's front and rear paired with some OME coils and possibly an AAL in the rear.
    @YotaDan or @HeadStrong Off-Road will definitely be able to take care of this for you!
    JT
    YotaDan likes this.
  11. Dec 15, 2016 at 8:03 AM
    superhedgey
    Brandon
    None
  12. Dec 15, 2016 at 8:05 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Lift spindles are they best bang for the buck on a PreRunner. FWIW
    Lord Helmet likes this.
  13. Dec 15, 2016 at 8:06 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    YotaDan and ChadsPride like this.
  14. Dec 17, 2016 at 4:35 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    In order to do a proper lift you will need to expand your budget considerably. You can go cheap but I wouldn't if I were you. Start with a spindle lift and go from there. If the funds are not available wait until they are before proceeding.
